Archived from groups: alt.comp.periphs.mainboard.fic (More info?)
Wblane wrote:
> I've got a VA503+ w/the following configuration:
> > 48MB EDO DRAM
> K62 400 (actually an overclocked K62-380)
> GeForce 2/GTS AGP vid-card
> 20GB and 15GB Hard drives
> 250Watt PSU
> 98SE
> > The problem is, I'm locked in 640x480x16 color mode. I can't switch
> resolutions! It's absolutely maddening.
The inability to select other resolutions is generally due to not having the correct video driver installed for your video card. That is, unless the card has insufficient memory or defective memory for a higher resolution. I would seek a current video driver for your video card if it were my machine.
> > I'm beginning to think it may be overheating (even though I've got an
> Athlon-class heatsink on it).
> > Any ideas anyone? I'd heard that the VA503+ wasn't very compatible w/AGP
> vid-cards.
> -Bill (remove "botizer" to reply via email)
Also, don't forget to have the correct monitor installed.
>48MB EDO DRAM
>250Watt PSU
>98SE
>vid-cards.
It turned out there was a memory conflict between the GeForce 2/GTS and an old
ISA SMC NIC. Once this was resolved all problems disappeared.
>>48MB EDO DRAM
>>250Watt PSU
>>98SE
>>vid-cards.
