After changing the motherboard xp won't load - urgent help..
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have just had to replace the motherboard in a machine that I recently built
as the original one failed after just over a month. Unfortunately the new
board is not the same model and now xp (with service pack 2 installed) won't
load. Whilst I could reinstall I don't want to lose my data as I didn't have
time to backup my files. Can anyone help I'm getting desparate I need to get
to this data and don't have access to another motherboard the same model as
before.
9 answers Last reply
More about after changing motherboard load urgent help
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > recently built as the original one failed after just over a month.
    > Unfortunately the new board is not the same model and now xp (with
    > service pack 2 installed) won't load. Whilst I could reinstall I
    > don't want to lose my data as I didn't have time to backup my files.
    > Can anyone help I'm getting desparate I need to get to this data and
    > don't have access to another motherboard the same model as before.
    Normally, and assuming a retail license (many OEM installations
    and licenses are not transferable to a new motherboard - check yours
    before starting), unless the new motherboard is virtually identical
    (same chipset, same IDE controllers, same BIOS version, etc.) to the
    one on which the WinXP installation was originally performed, you'll
    need to perform a repair (a.k.a. in-place upgrade) installation, at
    the very least:
    How to Perform an In-Place Upgrade of Windows XP
    http://support.microsoft.com/directory/article.asp?ID=KB;EN-US;Q315341
    The "why" is quite simple, really, and has nothing to do with
    licensing issues, per se; it's a purely technical matter, at this
    point. You've pulled the proverbial hardware rug out from under the
    OS. (If you don't like -- or get -- the rug analogy, think of it as
    picking up a Cape Cod style home and then setting it down onto a Ranch
    style foundation. It just isn't going to fit.) WinXP, like Win2K
    before it, is not nearly as "promiscuous" as Win9x when it comes to
    accepting any old hardware configuration you throw at it. On
    installation it "tailors" itself to the specific hardware found. This
    is one of the reasons that the entire WinNT/2K/XP OS family is so much
    more stable than the Win9x group.
    As always when undertaking such a significant change, back up any
    important data before starting.
    This will also probably require re-activation, unless you have a
    Volume Licensed version of WinXP Pro installed. If it's been more
    than 120 days since you last activated that specific Product Key,
    you'll most likely be able to activate via the internet without
    problem. If it's been less, you might have to make a 5 minute phone
    call.
    Bruce Chambers
    Help us help you:
    http://dts-l.org/goodpost.htm
    http://www.catb.org/~esr/faqs/smart-questions.html
    You can have peace. Or you can have freedom. Don't ever count on
    having
    both at once. - RAH
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hello Wendy
    You will need your windows xp cd to fix that.
    http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q315341&ID=KB;EN-US;Q315341
    Michael Ortega
    "Wendy E" <Wendy E@discussions.microsoft.com> wrote in message
    news:2D8D5CD4-D8B2-482F-8635-BCE51C6FBB95@microsoft.com...
    >built
    > won't
    > have
    > get
    > as
    > before.
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Thanks Michael I did try that but didn't continue as I have data I didn't
    want to lose I thought I would ask for help first. Anyhow I have managed to
    obtain another motherboard the same model as the original which I have
    ordered so I should be alright once that is installed. I'll then back up the
    data and decide which board I want to use and repartition the hard drive and
    reinstall it so that I have 2 partitions and won't have this problem again.
    "Michael Ortega" wrote:
    > Hello Wendy
    > Michael Ortega
    > >built
    > > won't
    > > have
    > > get
    > > as
    > > before.
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Wendy;
    After a motherboard replacement, a Repair Installation is usually
    required to properly detect the new hardware:
    http://www3.telus.net/dandemar/repaxp.htm
    Jupiter Jones [MVP]
    >recently built
    > the new
    > installed) won't
    > didn't have
    > need to get
    > model as
    > before.
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Wendy, don't follow the advice of Bruce, it is off the mark.
    JJ has the correct story. The Repair install will reset XP to the new
    hardware environment and also back to the state of your install disk - XP
    basic, XP SP1 - so SP2 will need to be reinstalled.
    Repair Install to SET XP to New Motherboard
    1. Do Not BOOT into Windows XP on first boot after Motherboard or Hard Drive
    change! If booting from CD is not an option, return to BIOS and make sure
    booting from CD is the first boot option.
    2. If your computer does not support booting from the CD, check your OEM or
    Motherboard makers web site for updated BIOS.
    3. Perform a Repair Install by following the step by step below.
    Wen you see the "Welcome To Setup" screen, you will see the options below
    This portion of the Setup program prepares Microsoft Windows XP to run on
    your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
    Press Enter to start the Windows Setup.
    Accept the License Agreement and Windows will search for existing Windows
    installations.
    Select the XP installation you want to repair from the list and press R to
    start the repair.
    Setup will copy the necessary files to the hard drive and reboot. Do not
    press any key to boot from CD when the message appears. Setup will continue
    as if it were doing a clean install, but your applications and settings will
    remain intact.
    Blaster worm warning: Do not immediately activate over the internet when
    asked, enable the XP firewall before connecting to the internet. You can
    activate after the firewall is enabled. Control Panel - Network Connections.
    Right click the connection you use, Properties, and there is a check box on
    the advanced page.
    Reapply updates or service packs applied since initial Windows XP
    installation.
    Activation
    What happens when you change a motherboard or move a hard drive depends on
    the accumulated changes made within a 120 day period since initial
    activation.
    It also depends on the version of Windows XP intended for the move.
    Retail versions of XP
    Rtail versions of XP can be moved from and reinstalled as many times as you
    want as long as it is in compliance with the EULA. The EULA states: You may
    install, use, access, display and run one copy of the Software on a single
    computer, such as a workstation, terminal or other device ("Workstation
    Computer")
    OEM versions of XP
    1. OEM versions of XP preinstalled on systems according to the OEM EULA
    cannot be transferred to another computer[or new Motherboard]. This is
    defined in the EULA.
    2. OEM versions sold with a piece of hardware are thought to be tied to the
    original computer it is installed on.
    For clarification: Contact
    Microsoft Corporate and Legal Affairs
    Microsoft Corporation
    One Microsoft Way
    Redmond, WA 98052-6399
    USA
    "Jupiter Jones [MVP]" wrote:
    > Wendy;
    > Jupiter Jones [MVP]
    > >recently built
    > > the new
    > > installed) won't
    > > didn't have
    > > need to get
    > > model as
    > > before.
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Thanks for this it answers my question particularly regarding my data. Since
    it will leave this intact I will try this now. As far as activation is
    concerned it is less than 120 days as it was only the 29 of August that I
    built the machine up and it was a retail version rather than an oem version
    so I know I'm ok there. As I said to Mchael I had got as far as that but
    didn't know if I would lose my data so I came out of it. I will try this now
    especially since I have realised what the administrator password was - the
    password I put in when I installed it - right. I don't worry about the
    security because I have Norton firewall on there too, but this is very
    useful. The board that I have ordered will be useful as a spare anyway and
    it only cost £27 so it was reasonable anyway. Thanks again.
    > your computer:
    > installations.
    > start the repair.
    > remain intact.
    > the advanced page.
    > installation.
    > Activation
    > activation.
    > Computer")
    > OEM versions of XP
    > One Microsoft Way
    > USA
    > > Wendy;
    > > Jupiter Jones [MVP]
    > > >recently built
    > > > the new
    > > > installed) won't
    > > > didn't have
    > > > need to get
    > > > model as
    > > > before.
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    "BAR" <BAR@discussions.microsoft.com> wrote in message
    news:DB17F69C-92EE-4915-8C85-602175EB476D@microsoft.com...
    > Drive
    (snip)
    BAR:
    In your excellent step-by-step instructions to the OP for carrying out a
    Repair install, you caution against an initial boot following a
    motherboard/hard drive change. I've seen the same cautionary note from other
    posters as well. Indeed, the Michael Steven's site, probably the most often
    recommended site for information on performing a Repair install also
    contains this advice. I've even come across statements to the effect that an
    initial boot before undertaking a Repair install could be "fatal", (whatever
    that means).
    Would you be good enough to explain why you believe this initial boot can
    cause problems? I raise this issue since I've had occasion to undertake
    perhaps 50 Repair installs on various machines after a motherboard/hard
    drive/processor/RAM, etc. change and I ALWAYS attempt an initial boot
    immediately following the change. Admittedly, in the vast majority of cases
    the system will not boot, however, in a few cases the system will boot,
    notwithstanding the fact that major components were changed and presumably
    the system should not have booted. But it did. And by so doing, the rather
    lengthy Repair install proved unnecessary. Should the initial boot fail, I
    proceed, of course, with a Repair install. I have never come across a single
    instance where performing a failed initial boot caused any subsequent
    problems of the OS that could be traced to a failed first boot in this
    situation.
    I would appreciate your further comments on this issue.
    Art
  8. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    How so? Please provide specific technical details.
    Bruce Chambers
    Help us help you:
    having
    both at once. - RAH
  9. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I think he was probably just saying that you hadn't answered my question. I
    already knew the information you gave, infact if you reread my post you will
    see that I state that by saying that I didn't have access to a board of the
    same model. However, I have managed to obtain one on ebay so problem solved.
    I mainly wanted to know if it is possible to get my data off. By the way, I
    have retail copy of xp so know that I can legally transfer it. Thanks for
    taking the time to help anyway.
    > Bruce Chambers
    > Help us help you:
    > having
    > both at once. - RAH
Motherboards Windows XP
