Problem: Switched from 8IK1100 v1 motherboard to the versi..
Anonymous
Archived from groups: alt.comp.periphs.gigabyte,alt.comp.periphs.mainboard.giga-byte,alt.comp.periphs.mainboard.gigabyte,alt.comp.hardware.homebuilt (More info?)
I'm out of ideas. I just swapped out my Gigabyte motherboard (model
no. 8IK1100 ver 1; blown capacitor) and replaced it with the newer
Version 2 model of the same motherboard.
Now, Windows XP Pro (Serv Pack 1) doesn't recognize the onboard sound
chip (Realtek AC97) at all. All else is normal.
I've tried loading the drivers again (latest from the Web), but it
doesn't fix the problem. The drivers on the CD don't t fix the prob
either.
What worries me most... the PC doesn't seem to realize I have the
onboard sound chip at all - when I open up the 'Sounds and Audio
devices' control pannel in WinXP, the AC97 sound chip isn't even
listed as an option. I've also tried 'Detect New Hardware' - still no
go.
Any ideas? I had no problems with the previous ver1 mb.
Best,
J Greenman
Detroit
(Fyi, I have another sound card in the machine. It's functioning
normally - it's a Hammerfall PCI sound card (not Soundblaster
compatible; it's used for professional multitrack recording & is not
designed to playback basic computer audio like games & mp3s, etc.)
either.
go.
Best,
J Greenman
Detroit
9
answers
Last reply
More about problem switched 8ik1100 motherboard versi
Is your onboard sound enabled in your BIOS? Also, the revision 2 board has
a newer 658 soundchip instead of the 655 chip on the revision 1 board. You
might be forced to do a repair install of Windows XP since you do have a new
motherboard and BIOS.
Russell
"Joe Greenman" <joegreenman@southsound.com> wrote in message
news:5276ad1e.0403311053.3f86433b@posting.google.com...
> either.
> go.
> Best,
> J Greenman
> Detroit
> designed to playback basic computer audio like games & mp3s, etc.) -
"Russell" wrote...
Yep, onboard sound is enabled. It just occured to me that I haven't
re-loaded the new (?) Intel chipset drivers (the ones that came with
the rev 2 mb; rev 1 chipset drivers are installed, of course,
already). Perhaps that's all that's needed?
Or, I might try removing my PCI sound card and see if the system
auto-recognizes the soundchip. (Then I'd reinstall the PCI card.)
Otherwise... it's off to do a Repair Install (grrr).
joe -
Joe,
Do a repair - they're easy. Make sure you resintall mobo drivers, all other
drivers, and Windows XP SP1 as well (if it is not already on your setup CD).
- Tim
news:5276ad1e.0404010850.265037b5@posting.google.com...
> "Russell" wrote...
has
You
new
> joe -
On Fri, 2 Apr 2004 15:05:18 +1200, "Tim" <Tim@NoSpam.com> wrote:
>Joe,
>- Tim
Do a repair install when the whole motherboard is the same except for the
sound? Geeze, windows has made everyone brain-dead. -
So, what is the difference between the v1 mobo and the v2 mobo then?
Is the bios identical? Is the bios interchangable between v1 and v2?
Are all the chips on the mobo the same?
Are all the chips initialised by the bios the same?
If they are that similar, then why is it called a v2 mobo.
Safest not to assume anything if you find things are not 100%.
Assumptions belong to the brain dead.
- Tim
"kony" <spam@spam.com> wrote in message
news:37qp609edvj4urncgdisnskqf0c6h6gp5s@4ax.com...
> >Joe,
other
CD).
> >- Tim
yes
N/A
You mean instead of a different model name?
Because they are that similar.
Did you assume a repair install should be done?
Might not be a safe assumption to make.
>- Tim
Did you miss the part about "everything else is normal"? -
Kony,
You are referring to a minor version change.
Don't confuse a V1 mobo with a V2 mobo.
A minor revision is 1001 to 1002 or 1003.
A version change is 1006 to 2001
In a minor version change all the major (active - "visible" to the OS) chips
will be the same, the bios will be the same and no OS repair is needed.
In a major version change secondary chips such as onboard sound, nic, and
other peripheral chips are usually the reason for change in the major
version number. There could also be revisions in the major chips on the
mobo. A minor version change is like a bug fix - the layout might be
improved, power regulator chips may change - things that are inconsequential
to the bios but either improve stability, reduce manufacturing costs or
reflect a new version in some minor chip EG voltage regulator.
Even on a minor version change mobo, there can be significant differences in
functionality arise over time where the supported OS, CPU's and so on can
change. This is likely to span several minor version numbers and be well
know - personally I think these should be reflected with changes in the
major version number.
If you would like to try your theories out and have lots of spare dosh then
I suggest getting a V1 8KNXP and a V2 8KNXP and swap the bios's over. I am
not about to do it on mine.
So, I will hold to my statement: if there is a major change in mobo revision
level, expect to have to do a repair - it may not be needed, but it might
and it is easy.
- Tim
news:66tq60hq3tkf1314l9v7vqjb81h79ofm34@4ax.com...
> yes
> N/A
> >- Tim
On Sat, 3 Apr 2004 20:17:49 +1200, "Tim" <Tim@NoSpam.com> wrote:
>Kony,
>and it is easy.
The issue of whether a repair is needed is primarily one of whether the
board will boot to the OS, at which point you can SEE what's going on,
change drivers, etc. At this point in the thread we already knew the box
would boot windows, it is now no different than troubleshooting any other
similar (sound card) issue. Would you do a repair install of an OS each
time you install new hardware, keeping in mind that you still need the
driver anyway, either way?
A repair install is just a waste of time unless it's needed. A system
that can boot to the desktop shouldn't need one unless the user simply
"gives up", but again, repair doesn't necessarily eliminate the same
scenario as prior to the repair, a viable driver. -
Remove the sound card, go into bios and enable the sound chip, then go to
device manager and remove and reinstall the device.
KK
> either.
> go.
> Best,
> J Greenman
> Detroit
Related Resources
Gigabyte
Motherboards
Related Resources
- Should I RMA my sound card or motherboard?
- HOW TO REPAIR A MOTHERBOARD
- Audio latency problem with P35-DS3R
- PCI sound card problem with 965P-DS3P
- Gigabyte GA-965P-DS3 Sound?
- New motherboard -- Problem with XP Repair - keeps rebooting
- Onboard Sound Recognized but Not Working
- Sound problem...... Help....
- Intel dz68db no sound from PCI sound card
- No Sound Problem
- Motherboard for P4.
- How to add a sound-card to my PC?
- Onboard sound issues?
- Realtek Onboard Sound
- Realtek onboard sound popping and crackling after a while
