Archived from groups: alt.comp.periphs.mainboard.giga-byte (More info?)
If you define 1GB as 1,000,000,000 bytes, as the drive manufacturers do,
then you bought a 160GB HDD.
If you define 1GB as 1,073,741,824 bytes, as Windows XP does, then you have
149GB.
Neither size is wrong, it all comes down to what your definition of a
gigabyte is.
"Terry" <redone22214@excite.com> wrote in message
news:Eu%Ac.5380$3b5.4515@newssvr27.news.prodigy.com...
> I have a Giga-byte GA-7VT600 1394 AMD Motherboard with dual bios and a
> Seagate Hard drive .
> The hard drive has a 160GB capacity,but when I install it with this
> hardware and WindowsXP OEM SP1 software it only comes up as a 150GB
> hard drive.
> Do I need to flash something or change a setting so it see's it as a
> 160GB hard drive.
> Thanks:Terry
also format and all the tables it has to store take space.
KK
"Homer J. Simpson" <hjsimpson@springfield.usa> wrote in message
news:Jq2Bc.818837$Ig.97412@pd7tw2no...
have
> 149GB.
> gigabyte is.
> > hard drive.
> > 160GB hard drive.
> > Thanks:Terry
