Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > MS Precision Wheel problem
Forum Windows XP : Windows XP General Discussion - MS Precision Wheel problem
Archived from groups: microsoft.public.mshardware.product,microsoft.public.windowsxp.hardware (More info?)
I have the MS Precision Wheel with the Sidewinder 4.0 software installed
on my WinXP Pro system. Since I bought the MS Precision 2 joystick and
installed its software I cannot access the 'Properties' of my wheel
under 'Game Controllers'. Every time I click on 'Properties' i get the
following error message:
"SideWinder Game Controller Software 4.0
There was an internal error that may be due to low system ressources.
Please close this program, as well as other open programs, and try
again. If the problem persists, your computer may be missing necessary
components of this program. Please reinstall the software"
I need the 'Properties', because I switch the pedals to combined axes
mode there for using them in flight sims.
I tried everything, I disconnected the joystick, uninstalled/reinstalled
everything - nothing seems to help...
Can anybody help? I cannot fly without rudder pedals... Thank you very
much in advance!
Wojtek Musial
P.S. Maybe you know an utility, which can switch two axes to 1 axis
directly through DirectX, so I dont need the SW Software for it...?
Sponsored Links
I would suggest either trying to uninstall and reinstall the Sidewinder
software....or searching your PC for joy.cpl, deleting the file and
reinstalling.
May be best to uninstall, reboot....confirm joy.cpl is no longer on the
system, then try to reinstall.
Steve
"Wojtek Musial" <www@wwww.de> wrote in message
news:417d81ad$0$535$9b622d9e@news.freenet.de...
> much in advance!
> Wojtek Musial
Reply to Anonymous
> reinstalling.
> Steve
Thanks for a good tip. Unfortunately it doesnt work :-(
I deleted joy.cpl (not that easy, because XP tries to restore it 'on the
fly'...) and after that 'Game Controllers' dissapeared, so I copied
another joy.cpl instead (from another machine), but the error message is
still there... hmm I run out of ideas... there must be a solution to it....
Reply to Anonymous
I don't believe the SideWinder software is supported in Windows XP.
Uninstall the software and add the device using the Game Controllers in
the Control Panel. Just select SideWinder (Auto-Detect) and XP should
automatically install it for you. This means you won't have all of the
features of the SideWinder software, but unfortunatley, the software
does not support XP.
Nathan McNulty
>> reinstalling.
>> Steve
Reply to Anonymous
The software does work under Windows XP. It sounds like you are either
trying to run it under a non-Administrator account (most likely cause, you
will get his error 100% of the time if you run under an account without
Administrator privileges), or you might have ended up replacing the device
driver that came with Windows XP with the version that came on the CD with
your device. The one on the CD is pretty much the same as the one in the OS
but the one in the OS had a couple fixes to it.
Joshua Smith
DirectInput Test Lab
Microsoft
Get Secure! www.microsoft.com/security
This post is provided "AS IS" with no warranties, and confers no rights
"Nathan McNulty" <newsgroups@msn.com> wrote in message
news:OFmWVryuEHA.1400@TK2MSFTNGP11.phx.gbl...
>Uninstall the software and add the device using the Game Controllers in the
>features of the SideWinder software, but unfortunatley, the software does
>not support XP.
> Nathan McNulty
>>> reinstalling.
>>> Steve
>> it....
Reply to Anonymous
Well, the SideWinder Software works under XP (it wasnt designed to but
it works...). Of course I can use Sidewinder Autodetect, but this won't
give me combined axes either... Everything worked without problems for
nearly 2 years before installing the joystick with its software...
Wojtek
Reply to Anonymous
I'm running my XP under an administrator account for sure, but it's
interesting you get this error message if running without admin rights.
I dont understand what you want to say here :)
Addition: By using the internal Sidewinder Autodetect driver I can use
the 'Properties', but there is no switch for combining axes...
Reply to Anonymous
That's interesting. Any documentation or KB Article as to what
Sidewinder Game Controllers can be used with their software and which
ones can't? It seems like most of them don't work with XP and just need
to use the generic drivers. Unfortunately, I'm not lucky enough to have
multiple MS Game Contollers :p
Nathan McNulty
Reply to Anonymous
Sidewinder 4.0 is supported in Windows XP
Sidewinder 3.02 (or earlier) is NOT supported in Windows XP.
Note that Sidewinder 4.0 was designed for the USB gaming devices that it
came with and not older Sidewinder devices.
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.com/default.aspx
>not support XP.
> Nathan McNulty
>>> reinstalling.
>>> Steve
>> it....
Reply to Anonymous
The 3.0 software for the gameport series of devices (yes some did have USB
dongles that allowed USB connections) does not work in Windows XP because it
is written in vxd format which isn't supported in NT (NT, Windows 200,
Windows XP, ect.). This is the only package you can download from an
official source on the web.
The Sidewinder team was completing development of the 4.0 USB only devices
before Windows 2000 was finished. For that reason, even though there was no
issues running it in Windows 2000, they added the message about possible
incompatibility if the install isn't on a Win9X system. During Windows XP
development the DirectInput team discovered some issues with the original
4.0 drivers from the CD in Windows XP. Since the 4.0 drivers were not
packaged or meant to be distributed by web downloads it was decided we would
add the updated 4.0 drivers into Windows XP and have them digitally signed.
Since the drivers on the CD are not signed if a user ran the install on the
CD Windows XP would choose to keep using the newer signed drivers (by
default) over the unsigned ones and only the configuration software would be
installed. The configuration software was not added to the OS because each
device had it's own package that included around 60MB of configuration files
ect. It was decided that running the install from the CD provided with the
device would only install the software needed by that particular device. It
is possible however to force the unsigned driver to be used through the
Device Manager by choosing to update the driver and then choosing the
unsigned one from the list and ignoring the warning about it being unsigned.
There is also a setting that can be changed that would allow an unsigned
driver to be chosen over the signed one. That setting is under "Driver
Signing" in the "System Properties" dialog (RightClick My Computer and
choose Properties, then select the Hardware tab).
Joshua Smith
DirectInput and OpenGL Test Labs
Microsoft
This posting is provided "AS IS" with no warranties, and confers no rights
news:ONQb$1$uEHA.940@TK2MSFTNGP14.phx.gbl...
> That's interesting. Any documentation or KB Article as to what Sidewinder
> Game Controllers can be used with their software and which ones can't? It
> seems like most of them don't work with XP and just need to use the
> generic drivers. Unfortunately, I'm not lucky enough to have multiple MS
> Game Contollers :p
> Nathan McNulty
>> you will get his error 100% of the time if you run under an account
>> without Administrator privileges), or you might have ended up replacing
>> the device driver that came with Windows XP with the version that came on
>> the CD with your device. The one on the CD is pretty much the same as the
>> one in the OS but the one in the OS had a couple fixes to it.
Reply to Anonymous
Hi Wojtek,
Can you send me a dxdiag report of your system? The Sidewinder Autodetect is
really the 3.02 driver that was put into the OS since the 3.02
software/driver package was blocked because the software (being in vxd
format) wouldn't run on Windows XP. It is only going to work for the older
gameport devices.
DXDIAG:
1. Click Start -> Run
2. Type "dxdiag" without the quotes and press Ok.
3. In the DirectX Diagnostic tool click "Save All Information..."
Joshua Smith
Microsoft
news:417e6161$0$167$9b622d9e@news.freenet.de...
>> not support XP.
> Well, the SideWinder Software works under XP (it wasnt designed to but it
> works...). Of course I can use Sidewinder Autodetect, but this won't give
> me combined axes either... Everything worked without problems for nearly 2
> Wojtek
Reply to Anonymous
I tried to send the dxdiag report to your email adress, but it doesn't
work... I hope nobody feels offended if I send it here (it's 'only'
37kb). Thank you for taking your time for me!
Here is the report:
System Information
Time of this report: 10/27/2004, 19:55:28
Machine name: WOJTEK
Operating System: Windows XP Professional (5.1, Build 2600)
(2600.xpclient.010817-1148)
Language: English (Regional Setting: German)
System Manufacturer: VIA
System Model: 7VTXE
BIOS: Version 1.00
Processor: AMD Athlon(tm) XP 1700+, ~1.5GHz
Memory: 512MB RAM
Page File: 216MB used, 1033MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed,
which means that it has not been tested by Microsoft's Windows Hardware
Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from
the hardware manufacturer.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce3 Ti 200
Manufacturer: NVIDIA
Chip type: GeForce3 Ti 200
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0201&SUBSYS_10D21554&REV_A3
Display Memory: 64.0 MB
Current Mode: 1152 x 864 (32 bit) (85Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.6177 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 7/15/2004 11:42:00, 3740032 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 7/15/2004 11:42:00, 2459712 bytes
Device Identifier: {D7B71E3E-4141-11CF-C56E-D83002C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0201
SubSys ID: 0x10D21554
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2)
Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1)
DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0)
DeinterlaceTech_BOBVerticalStretch
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2)
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0)
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: VIA AC'97 Enhanced Audio (WAVE)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_A0021458&REV_30
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: viaudio.sys
Driver Version: 5.12.0001.3513 (English)
WHQL Logo'd: Yes
Date and Size: 9/10/2001 01:30:00, 42880 bytes
Other Files:
Driver Provider: VIA Technologies, Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: Modem #2 Line Playback (emulated)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
HW Memory: 0
Registry: OK
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
Description: Modem #2 Line Record (emulated)
Default Sound Capture: No
Default Voice Capture: No
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x20
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode),
Output, DLS, Internal, Default Port
VIA AC'97 Enhanced Audio (WAVE), Software (Kernel
Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not
Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware
(Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: SideWinder Precision Racing Wheel USB version 1.0
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x001A
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/23/2001 12:00:00, 50688 bytes
| Driver: usbd.sys, 8/23/2001 12:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/23/2001 12:00:00, 62464 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/17/2001 14:02:32, 9728 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/23/2001 12:00:00, 50944 bytes
| Driver: kbdclass.sys, 8/23/2001 12:00:00, 23424 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/17/2001 22:38:00, 37896 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 8/23/2001 12:00:00, 22016 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll
(5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll
(5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll
(5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll
(5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File:
dpwsockx.dll (5.03.0001.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll
(5.03.0001.0904)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll
(5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll
(5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not
run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay8 TCP/IP Service Provider: freenet flatrate - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 0.3 GB
Total Space: 19.6 GB
File System: FAT32
Model: IC35L060AVVA07-0
Drive: D:
Free Space: 6.4 GB
Total Space: 39.0 GB
File System: FAT32
Drive: E:
Model: MSI CD-RW MS-8348
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.0000
(German), 8/23/2001 12:00:00, 47488 bytes
Drive: F:
Model: TOSHIBA DVD-ROM SD-M1712
Drive: G:
Model: Generic DVD-ROM SCSI CdRom Device
Drive: H:
Model: AXV CD/DVD-ROM SCSI CdRom Device
System Devices
Name: VIA Tech CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_B099&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\VIAAGP.SYS, 5.01.2600.0000
(English), 8/17/2001 13:58:02, 27392 bytes
Name: VIA Tech CPU to PCI Bridge
Device ID: PCI\VEN_1106&DEV_3099&SUBSYS_00000000&REV_00\3&61AAA01&0&00
Driver: n/a
Name: VIA Tech PCI to ISA bridge
Device ID: PCI\VEN_1106&DEV_3074&SUBSYS_00000000&REV_00\3&61AAA01&0&88
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000
(English), 8/23/2001 12:00:00, 35840 bytes
Name: VIA AC'97 Enhanced Audio Controller (WDM)
Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_A0021458&REV_30\3&61AAA01&0&8D
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.0000
(English), 8/17/2001 14:01:20, 57344 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.0000
(English), 8/17/2001 22:24:38, 135040 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0001.0904
(German), 7/9/2004 04:27:28, 48512 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English),
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (German),
12/12/2002 00:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\viaudio.sys, 5.12.0001.3513
(English), 9/10/2001 01:30:00, 42880 bytes
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1B\3&61AAA01&0&8C
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.0000
(English), 8/23/2001 12:00:00, 18944 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.0000
(English), 8/23/2001 12:00:00, 123264 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English),
8/17/2001 22:36:34, 67072 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.0000
(English), 8/23/2001 12:00:00, 50688 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1B\3&61AAA01&0&8B
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1B\3&61AAA01&0&8A
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711106&REV_06\3&61AAA01&0&89
Driver: C:\WINDOWS\System32\DRIVERS\viaide.sys, 1.00.0001.0000
(English), 8/23/2001 12:00:00, 4352 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.0000
(German), 8/23/2001 12:00:00, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 8/23/2001 12:00:00,
86656 bytes
Name: NVIDIA GeForce3 Ti 200
Device ID: PCI\VEN_10DE&DEV_0201&SUBSYS_10D21554&REV_A3\4&618BA55&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.6177
(English), 7/15/2004 11:42:00, 2459712 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.6177 (English),
7/15/2004 11:42:00, 114755 bytes
Driver: C:\WINDOWS\System32\nvcod.dll, 1.00.0000.0015 (English),
7/15/2004 11:42:00, 32256 bytes
Driver: C:\WINDOWS\System32\nvcodins.dll, 1.00.0000.0015 (English),
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.6177 (English),
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.6177 (English),
7/15/2004 11:42:00, 5222400 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.6177 (English),
7/15/2004 11:42:00, 4112384 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.6177 (English),
7/15/2004 11:42:00, 81920 bytes
Driver: C:\WINDOWS\System32\nvwddi.dll, 6.14.0010.6177 (English),
Driver: C:\WINDOWS\System32\nvnt4cpl.dll, 6.14.0010.6177 (English),
7/15/2004 11:42:00, 241664 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 7/15/2004 11:42:00, 154770 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 7/15/2004 11:42:00, 51281 bytes
Name: D346PRT SCSI Controller
Device ID: PCI\D346PRT\0000
Driver: n/a
Name: A347SCSI SCSI Controller
Device ID: PCI\A347SCSI\0000
Driver: n/a
DirectX Components
ddraw.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
265728 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
10496 bytes
d3d8.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
1179648 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
8192 bytes
d3d9.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
1689600 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02
797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00
33040 bytes
dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
230400 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
22016 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00
42768 bytes
dpwsockx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
57856 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
377856 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
203264 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02
32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02
68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00
53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00
151552 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00
168960 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
394240 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00
208896 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
76800 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00
31744 bytes
gameenum.sys: 5.01.2600.0000 English Final Retail 8/17/2001 14:02:32
9728 bytes
hidgame.sys: 5.01.2600.0000 English Final Retail 8/17/2001 14:02:32
8576 bytes
dsound.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
363520 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
68096 bytes
dmusic.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
104448 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
58368 bytes
dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
181248 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
76800 bytes
system.dll: 1.01.4322.0573 English Final Retail 7/14/2004 08:16:40
1216512 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02
1189888 bytes
dxdiagn.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
1769472 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 12:00:00
924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/23/2001 12:00:00
995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02
53248 bytes
dxmasf.dll: 6.04.0009.1120 English Final Retail 8/23/2001 12:00:00
498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40
241664 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
177152 bytes
qdv.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28
276480 bytes
qdvd.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28
382976 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
524800 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02
1246208 bytes
strmdll.dll: 4.01.0000.3925 English Final Retail 8/23/2001 12:00:00
246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/23/2001 12:00:00
199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/23/2001 12:00:00
848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/23/2001 12:00:00
120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/23/2001 12:00:00
338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/23/2001 12:00:00
755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/23/2001 12:00:00
200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/23/2001 12:00:00
183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/23/2001 12:00:00
154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
194560 bytes
msdvdopt.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00
74240 bytes
ks.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32
130304 bytes
ksproxy.ax: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32
117248 bytes
ksuser.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32
4096 bytes
stream.sys: 5.03.0001.0904 German Final Retail 7/9/2004 04:27:28
48512 bytes
mspclock.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32
5248 bytes
mspqm.sys: 5.01.2600.0000 German Final Retail 8/23/2001 05:00:00
4608 bytes
mskssrv.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32
7424 bytes
swenum.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32
4096 bytes
mstee.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32
5504 bytes
bdaplgin.ax: 5.03.0000.0900 German Final Retail 7/9/2004 04:26:38
16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38
11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38
52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40
354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40
30208 bytes
ipsink.ax: 5.03.0000.0900 German Final Retail 7/9/2004 04:26:38
14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38
57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38
10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38
15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40
14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38
1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40
10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38
83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38
16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40
27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38
16896 bytes
kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 16:19:30
285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38
39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40
226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40
18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40
47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38
52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.00.0002.0000
InterVideo Video Decoder,0x00700000,2,3,ivivideo.ax,4.00.0005.0020
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
InterVideo Audio Processor,0x00400000,1,1,IviAudioProcess.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0904
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression
Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4477
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression
Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
Microsoft Screen Video
Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4477
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1120
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0904
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4477
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1120
NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1120
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0904
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
Microsoft MPEG-4 Video
Decompressor,0x00800000,1,1,mp4sds32.ax,8.00.0000.0344
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
InterVideo Audio Decoder,0x00700000,1,1,iviaudio.ax,4.00.0005.0020
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4477
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0904
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0904
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
..RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1120
InterVideo Navigator,0x00190000,0,3,ivinav.ax,4.00.0005.0020
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0904
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1120
ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMP CD Filter,0x00600000,0,1,wmpcd.dll,8.00.0000.4477
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0904
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.0770
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1120
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information
Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression
Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.0000.0900
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0904
Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX Pro 5.0.2 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
VIA AC'97 Enhanced Audio (WAVE),0x00200000,0,0,qcap.dll,6.05.0001.0900
Modem #2 Line Record,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming Capture Devices:
VIA AC'97 Enhanced Audio (WAVE),0x00200000,3,2,,5.03.0000.0900
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00200000,2,2,,5.03.0000.0900
Audio Renderers:
VIA AC'97 Enhanced Audio (WAVE),0x00200000,1,0,quartz.dll,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: Modem #2 Line Playback
(emulated),0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: VIA AC'97 Enhanced Audio
Modem #2 Line Playback,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming System Devices:
VIA AC'97 Enhanced Audio (WAVE),0x00200000,12,2,,5.03.0000.0900
Reply to Anonymous
Awesome, thanks Josh :)
Nathan McNulty
> Joshua Smith
> Microsoft
>>Game Contollers :p
>>Nathan McNulty
Reply to Anonymous
Remove the online string from the e-mail address and it should work.
news:417fe664$0$145$9b622d9e@news.freenet.de...
>work... I hope nobody feels offended if I send it here (it's 'only' 37kb).
> Here is the report:
> System Information
> System Model: 7VTXE
> BIOS: Version 1.00
> Memory: 512MB RAM
> DxDiag Notes
> Display Tab 1: The file nv4_disp.dll is not digitally signed, which
> means that it has not been tested by Microsoft's Windows Hardware Quality
> Labs (WHQL). You may be able to get a WHQL logo'd driver from the
> Direct3D: 0/4 (n/a)
> Display Devices
> WHQL Logo'd: No
> VDD: n/a
> Vendor ID: 0x10DE
> Device ID: 0x0201
> Revision ID: 0x00A3
> Revision ID: 0x00A3
> Registry: OK
> D3D Status: Enabled
> AGP Status: Enabled
> Sound Devices
> Manufacturer ID: 1
> Product ID: 100
> Type: WDM
> WHQL Logo'd: Yes
> Other Files:
> Cap Flags: 0xF5F
> HW Memory: 0
> Registry: OK
> Hardware ID:
> Manufacturer ID: 1
> Product ID: 81
> Type: Emulated
> Driver Name:
> Driver Version:
> Driver Attributes:
> WHQL Logo'd:
> Date and Size:
> Other Files:
> Driver Provider:
> Cap Flags: 0x0
> HW Memory: 0
> Registry: OK
> Cap Flags: 0x41
> Format Flags: 0xFFF
> Driver Name:
> Driver Version:
> Driver Attributes:
> Date and Size:
> Cap Flags: 0x20
> Format Flags: 0x0
> DirectMusic
> Acceleration: n/a
> VIA AC'97 Enhanced Audio (WAVE), Software (Kernel Mode),
> Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel
> Registry: OK
> DirectInput Devices
> Device Name: Mouse
> Attached: 1
> Controller ID: n/a
> FF Driver: n/a
> Attached: 1
> Controller ID: n/a
> FF Driver: n/a
> Attached: 1
> Controller ID: 0x0
> FF Driver: n/a
> Registry: OK
> USB Devices
> + USB Root Hub
> | Service: usbhub
> Gameport Devices
> + PCI bus
> | Service: pci
> | | Service: gameenum
> PS/2 Devices
> | Service: i8042prt
> | Service: TermDD
> | Service: i8042prt
> | Service: TermDD
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0001.0904)
> (5.03.0000.0900)
> (5.03.0000.0900)
> DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run,
> Mic: Not run
> Registry: OK
> DirectPlay Adapters
> MS-PCM 64 kbit/s
> Drive: C:
> Free Space: 0.3 GB
> File System: FAT32
> Drive: D:
> Free Space: 6.4 GB
> File System: FAT32
> Drive: E:
> Drive: F:
> Drive: G:
> Drive: H:
> System Devices
> Driver: n/a
> Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.0000 (English),
> 86656 bytes
> Driver: n/a
> Driver: n/a
> DirectX Components
> ddraw.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 265728
> bytes
> 24064 bytes
> dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 10496
> bytes
> 1179648 bytes
> d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192
> bytes
> 1689600 bytes
> 436224 bytes
> 797184 bytes
> 590336 bytes
> 350208 bytes
> d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 47616
> bytes
> d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 34816
> bytes
> dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00 33040
> bytes
> dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 230400
> bytes
> 22016 bytes
> dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00 42768
> bytes
> dpwsockx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 57856
> bytes
> 28160 bytes
> 16896 bytes
> 377856 bytes
> dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072
> bytes
> dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072
> bytes
> 203264 bytes
> 80896 bytes
> 112128 bytes
> 19968 bytes
> dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768
> bytes
> dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096
> bytes
> dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00 53520
> bytes
> 151552 bytes
> 168960 bytes
> dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 44032
> bytes
> 394240 bytes
> 208896 bytes
> gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 76800
> bytes
> pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744
> bytes
> gameenum.sys: 5.01.2600.0000 English Final Retail 8/17/2001 14:02:32 9728
> bytes
> hidgame.sys: 5.01.2600.0000 English Final Retail 8/17/2001 14:02:32 8576
> bytes
> dsound.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 363520
> bytes
> 1294336 bytes
> 18432 bytes
> 186880 bytes
> 68096 bytes
> dmusic.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 104448
> bytes
> 27136 bytes
> 58368 bytes
> dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 181248
> bytes
> 33280 bytes
> 98816 bytes
> 100864 bytes
> 76800 bytes
> 1216512 bytes
> 602624 bytes
> 1189888 bytes
> 1769472 bytes
> 924432 bytes
> mfc42.dll: 6.00.8665.0000 English Beta Retail 8/23/2001 12:00:00 995383
> bytes
> wsock32.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 21504
> bytes
> 64512 bytes
> devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 53248
> bytes
> 498205 bytes
> 34304 bytes
> 136192 bytes
> 13312 bytes
> 18944 bytes
> 241664 bytes
> 177152 bytes
> qdv.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 276480
> bytes
> qdvd.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 382976
> bytes
> 524800 bytes
> 733184 bytes
> 1246208 bytes
> 246302 bytes
> 199680 bytes
> 848384 bytes
> 120320 bytes
> 338432 bytes
> 755200 bytes
> 200192 bytes
> 183808 bytes
> 154624 bytes
> 194560 bytes
> msdvdopt.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 74240
> bytes
> 130304 bytes
> 117248 bytes
> ksuser.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 4096
> bytes
> stream.sys: 5.03.0001.0904 German Final Retail 7/9/2004 04:27:28 48512
> bytes
> mspclock.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 5248
> bytes
> mspqm.sys: 5.01.2600.0000 German Final Retail 8/23/2001 05:00:00 4608
> bytes
> mskssrv.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 7424
> bytes
> swenum.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 4096
> bytes
> mstee.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 5504
> bytes
> bdaplgin.ax: 5.03.0000.0900 German Final Retail 7/9/2004 04:26:38 16896
> bytes
> bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392
> bytes
> msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224
> bytes
> psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816
> bytes
> psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208
> bytes
> ipsink.ax: 5.03.0000.0900 German Final Retail 7/9/2004 04:26:38 14848
> bytes
> mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 57856
> bytes
> ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112
> bytes
> mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104
> bytes
> streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976
> bytes
> 1230336 bytes
> slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880
> bytes
> nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968
> bytes
> ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384
> bytes
> vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 27648
> bytes
> msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896
> bytes
> 285696 bytes
> ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424
> bytes
> kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 226304
> bytes
> wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688
> bytes
> wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 47104
> bytes
> msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096
> bytes
> DirectShow Filters
> DirectShow Filters:
> Video Compressors:
> Audio Compressors:
> Midi Renderers:
> Audio Renderers:
Reply to Anonymous
You needed to take the online part out of his email address ;)
Nathan McNulty
> Here is the report:
> System Information
> System Model: 7VTXE
> BIOS: Version 1.00
> Memory: 512MB RAM
> DxDiag Notes
> Direct3D: 0/4 (n/a)
> Display Devices
> WHQL Logo'd: No
> VDD: n/a
> Vendor ID: 0x10DE
> Device ID: 0x0201
> Revision ID: 0x00A3
> Revision ID: 0x00A3
> Registry: OK
> D3D Status: Enabled
> AGP Status: Enabled
> Sound Devices
> Manufacturer ID: 1
> Product ID: 100
> Type: WDM
> WHQL Logo'd: Yes
> Other Files:
> Cap Flags: 0xF5F
> HW Memory: 0
> Registry: OK
> Hardware ID:
> Manufacturer ID: 1
> Product ID: 81
> Type: Emulated
> Driver Name:
> Driver Version:
> Driver Attributes:
> WHQL Logo'd:
> Date and Size:
> Other Files:
> Driver Provider:
> Cap Flags: 0x0
> HW Memory: 0
> Registry: OK
> Cap Flags: 0x41
> Format Flags: 0xFFF
> Driver Name:
> Driver Version:
> Driver Attributes:
> Date and Size:
> Cap Flags: 0x20
> Format Flags: 0x0
> DirectMusic
> Acceleration: n/a
> Registry: OK
> DirectInput Devices
> Device Name: Mouse
> Attached: 1
> Controller ID: n/a
> FF Driver: n/a
> Attached: 1
> Controller ID: n/a
> FF Driver: n/a
> Attached: 1
> Controller ID: 0x0
> FF Driver: n/a
> Registry: OK
> USB Devices
> + USB Root Hub
> | Service: usbhub
> Gameport Devices
> + PCI bus
> | Service: pci
> | | Service: gameenum
> PS/2 Devices
> | Service: i8042prt
> | Service: TermDD
> | Service: i8042prt
> | Service: TermDD
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0001.0904)
> (5.03.0000.0900)
> (5.03.0000.0900)
> run, Mic: Not run
> Registry: OK
> DirectPlay Adapters
> MS-PCM 64 kbit/s
> Drive: C:
> Free Space: 0.3 GB
> File System: FAT32
> Drive: D:
> Free Space: 6.4 GB
> File System: FAT32
> Drive: E:
> Drive: F:
> Drive: G:
> Drive: H:
> System Devices
> Driver: n/a
> 86656 bytes
> Driver: n/a
> Driver: n/a
> DirectX Components
> 265728 bytes
> 24064 bytes
> 10496 bytes
> 1179648 bytes
> 8192 bytes
> 1689600 bytes
> 436224 bytes
> 797184 bytes
> 590336 bytes
> 350208 bytes
> 47616 bytes
> 34816 bytes
> 33040 bytes
> 230400 bytes
> 22016 bytes
> 42768 bytes
> 57856 bytes
> 28160 bytes
> 16896 bytes
> 377856 bytes
> 3072 bytes
> 3072 bytes
> 203264 bytes
> 80896 bytes
> 112128 bytes
> 19968 bytes
> 32768 bytes
> 68096 bytes
> 53520 bytes
> 151552 bytes
> 168960 bytes
> 44032 bytes
> 394240 bytes
> 208896 bytes
> 76800 bytes
> 31744 bytes
> 9728 bytes
> 8576 bytes
> 363520 bytes
> 1294336 bytes
> 18432 bytes
> 186880 bytes
> 68096 bytes
> 104448 bytes
> 27136 bytes
> 58368 bytes
> 181248 bytes
> 33280 bytes
> 98816 bytes
> 100864 bytes
> 76800 bytes
> 1216512 bytes
> 602624 bytes
> 1189888 bytes
> 1769472 bytes
> 924432 bytes
> 995383 bytes
> 21504 bytes
> 64512 bytes
> 53248 bytes
> 498205 bytes
> 34304 bytes
> 136192 bytes
> 13312 bytes
> 18944 bytes
> 241664 bytes
> 177152 bytes
> 276480 bytes
> 382976 bytes
> 524800 bytes
> 733184 bytes
> 1246208 bytes
> 246302 bytes
> 199680 bytes
> 848384 bytes
> 120320 bytes
> 338432 bytes
> 755200 bytes
> 200192 bytes
> 183808 bytes
> 154624 bytes
> 194560 bytes
> 74240 bytes
> 130304 bytes
> 117248 bytes
> 4096 bytes
> bytes
> 5248 bytes
> bytes
> 7424 bytes
> 4096 bytes
> 5504 bytes
> bytes
> 11392 bytes
> 52224 bytes
> 354816 bytes
> 30208 bytes
> bytes
> 57856 bytes
> 10112 bytes
> 15104 bytes
> 14976 bytes
> 1230336 bytes
> 10880 bytes
> 83968 bytes
> 16384 bytes
> 27648 bytes
> 16896 bytes
> 285696 bytes
> 39424 bytes
> 226304 bytes
> 18688 bytes
> 47104 bytes
> 52096 bytes
> DirectShow Filters
> DirectShow Filters:
> Video Compressors:
> Audio Compressors:
> Midi Renderers:
> Audio Renderers:
Reply to Anonymous
I see a couple things we can try to get you going.
First lets make sure you are using the correct driver. We can use the steps
in this KB article for that.
http://support.microsoft.com/defau [...] -us;299039
Next, if that doesn't fix it we should update the USB drivers for your VIA
USB controller. There have been issues in the past with some VIA USB
chipsets, and it looks like you are running the drivers that came with
Windows XP. If you can't find updated drivers from your manufacturer you can
try the ones at www.viaarena.com . I have heard of people using those
successfully in the past.
Joshua Smith
Microsoft
> Here is the report:
> System Information
> System Model: 7VTXE
> BIOS: Version 1.00
> Memory: 512MB RAM
> DxDiag Notes
> Direct3D: 0/4 (n/a)
> Display Devices
> WHQL Logo'd: No
> VDD: n/a
> Vendor ID: 0x10DE
> Device ID: 0x0201
> Revision ID: 0x00A3
> Revision ID: 0x00A3
> Registry: OK
> D3D Status: Enabled
> AGP Status: Enabled
> Sound Devices
> Manufacturer ID: 1
> Product ID: 100
> Type: WDM
> WHQL Logo'd: Yes
> Other Files:
> Cap Flags: 0xF5F
> HW Memory: 0
> Registry: OK
> Hardware ID:
> Manufacturer ID: 1
> Product ID: 81
> Type: Emulated
> Driver Name:
> Driver Version:
> Driver Attributes:
> WHQL Logo'd:
> Date and Size:
> Other Files:
> Driver Provider:
> Cap Flags: 0x0
> HW Memory: 0
> Registry: OK
> Cap Flags: 0x41
> Format Flags: 0xFFF
> Driver Name:
> Driver Version:
> Driver Attributes:
> Date and Size:
> Cap Flags: 0x20
> Format Flags: 0x0
> DirectMusic
> Acceleration: n/a
> Registry: OK
> DirectInput Devices
> Device Name: Mouse
> Attached: 1
> Controller ID: n/a
> FF Driver: n/a
> Attached: 1
> Controller ID: n/a
> FF Driver: n/a
> Attached: 1
> Controller ID: 0x0
> FF Driver: n/a
> Registry: OK
> USB Devices
> + USB Root Hub
> | Service: usbhub
> Gameport Devices
> + PCI bus
> | Service: pci
> | | Service: gameenum
> PS/2 Devices
> | Service: i8042prt
> | Service: TermDD
> | Service: i8042prt
> | Service: TermDD
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0000.0900)
> (5.03.0001.0904)
> (5.03.0000.0900)
> (5.03.0000.0900)
> Mic: Not run
> Registry: OK
> DirectPlay Adapters
> MS-PCM 64 kbit/s
> Drive: C:
> Free Space: 0.3 GB
> File System: FAT32
> Drive: D:
> Free Space: 6.4 GB
> File System: FAT32
> Drive: E:
> Drive: F:
> Drive: G:
> Drive: H:
> System Devices
> Driver: n/a
> 86656 bytes
> Driver: n/a
> Driver: n/a
> DirectX Components
> bytes
> 24064 bytes
> bytes
> 1179648 bytes
> bytes
> 1689600 bytes
> 436224 bytes
> 797184 bytes
> 590336 bytes
> 350208 bytes
> bytes
> bytes
> bytes
> bytes
> 22016 bytes
> bytes
> bytes
> 28160 bytes
> 16896 bytes
> 377856 bytes
> bytes
> bytes
> 203264 bytes
> 80896 bytes
> 112128 bytes
> 19968 bytes
> bytes
> bytes
> bytes
> 151552 bytes
> 168960 bytes
> bytes
> 394240 bytes
> 208896 bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> 1294336 bytes
> 18432 bytes
> 186880 bytes
> 68096 bytes
> bytes
> 27136 bytes
> 58368 bytes
> bytes
> 33280 bytes
> 98816 bytes
> 100864 bytes
> 76800 bytes
> 1216512 bytes
> 602624 bytes
> 1189888 bytes
> 1769472 bytes
> 924432 bytes
> bytes
> bytes
> 64512 bytes
> bytes
> 498205 bytes
> 34304 bytes
> 136192 bytes
> 13312 bytes
> 18944 bytes
> 241664 bytes
> 177152 bytes
> bytes
> bytes
> 524800 bytes
> 733184 bytes
> 1246208 bytes
> 246302 bytes
> 199680 bytes
> 848384 bytes
> 120320 bytes
> 338432 bytes
> 755200 bytes
> 200192 bytes
> 183808 bytes
> 154624 bytes
> 194560 bytes
> bytes
> 130304 bytes
> 117248 bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> 1230336 bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> 285696 bytes
> bytes
> bytes
> bytes
> bytes
> bytes
> DirectShow Filters
> DirectShow Filters:
> Video Compressors:
> Audio Compressors:
> Midi Renderers:
> Audio Renderers:
Reply to Anonymous
I changed the USB driver, without any effect... is there a possibility
to switch to combined axes 'by hand' in some .ini's or is there an
wholly other driver used in the combined mode?
I will try to check with filemon from sysinternals.com which files are
affected when clicking 'Properties' - perhaps something is missing...
Wojtek
> Joshua Smith
> Microsoft
Reply to Anonymous
I am pretty sure it is a reg key. I'll see if I can dig it up today or
tomorrow for you.
Joshua Smith
Microsoft
news:41812938$0$175$9b622d9e@news.freenet.de...
>I changed the USB driver, without any effect... is there a possibility to
>switch to combined axes 'by hand' in some .ini's or is there an wholly
> Wojtek
>> steps in this KB article for that.
>> VIA USB controller. There have been issues in the past with some VIA USB
>> can try the ones at www.viaarena.com . I have heard of people using those
>> Joshua Smith
>> Microsoft
Reply to Anonymous
> tomorrow for you.
I appreciate your help, thank you :)
The last resort is of course reinstalling XP, but I my system is so well
configured and I have so much stuff installed...
Reply to Anonymous
Yes,
Sidewinder 4.0 software works beautifully in my XP Pro system, with a MS
Sidewinder FF wheel and pedals - usb.
Don Burnette
> it came with and not older Sidewinder devices.
>> in the Control Panel. Just select SideWinder (Auto-Detect) and XP
>> should automatically install it for you. This means you won't have
>> all of the features of the SideWinder software, but unfortunatley,
>> the software does not support XP.
>> Nathan McNulty
>>>> Sidewinder software....or searching your PC for joy.cpl, deleting
>>>> the file and reinstalling.
>>>> on the system, then try to reinstall.
>>>> Steve
>>> 'on the fly'...) and after that 'Game Controllers' dissapeared, so
>>> I copied another joy.cpl instead (from another machine), but the
>>> error message is still there... hmm I run out of ideas... there
Reply to Anonymous
I am still trying to get a developer to dig this up for me. Sorry for the
delay.
Joshua Smith
Microsoft
news:4181897c$0$194$9b622d9e@news.freenet.de...
>> tomorrow for you.
Reply to Anonymous
No problem, I hope you succeed ;)
> delay.
Reply to Anonymous
Ok, finally I did a complete XP reinstall and it works :)
Thanks for all the help (especially Josh)!
Wojtek
Reply to Anonymous
That's good to hear, but what if I no longer have the 4.0 Game Controller
Software CD for my Sidewinder Game Pad USB? I cannot seem to find the
software on any Microsoft page...Any help guys?
> Wojtek
Reply to Anonymous
Hi Debbie,
You can request a new one to be sent to you here:
Hardware and Software replacement
http://support.microsoft.com/defau [...] -us;326246
Joshua Smith
Microsoft
"Debbie Rollins" <Debbie Rollins@discussions.microsoft.com> wrote in message
news:8A236BF8-4E08-4DA6-9C5C-19175AE0477D@microsoft.com...
>> Wojtek
Reply to Anonymous
I'm having a different problem. I have the 4.0 disc Microsoft sent me but
when I try and instal I get this error:
C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The System file is not suitable for running
MS-DOS and Microsoft Windows Applications.
I've tried all the Setup programs on the disc and get the same error. I
have a Sidewinder Wheel NON Force Feedback with USB connect.
"Joshua Smith [MSFT]" wrote:
> Hi Debbie,
> Joshua Smith
> Microsoft
> >> Wojtek
Reply to Anonymous
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
It is needed for 16 bit programs - and a lot of these installers are
still 16 bit
It is damaged - probably by a trojan (so test). You can get a clean
copy from C:\windows\repair and copy it over the present one in
C:\Windows\system32
Alex Nichol MS MVP (Windows Technologies)
Bournemouth, U.K. Alexn@mvps.D8E8L.org (remove the D8 bit)
Reply to Anonymous
Your autoexec.nt file probably became corrupt due to spyware.
I've attached a clean copy for you here.
Place it in the \Windows\System32 directory.
"Sean Addam" <Sean Addam@discussions.microsoft.com> wrote in message
news:296FB971-B92B-4DEE-AEF3-1D53AB987590@microsoft.com...
> running
>> Hi Debbie,
>> Joshua Smith
>> Microsoft
>> rights
>> message
>> > Controller
>> >> Wojtek
begin 666 AUTOEXEC.NT
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74D5-(" @(%-%5"!"3$%35$52/4$P#0H`
end
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > MS Precision Wheel problem
There are 1100 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
