Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > ATI Radeon All In Wonder 9600 XT boot to safe mode problem..
Forum Windows XP : Windows XP General Discussion - ATI Radeon All In Wonder 9600 XT boot to safe mode problem..
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have installed a new 9600 XT. There are a couple of problems. If I
try to boot to safe mode, the screen will go black and I get a
message:
Out of range
set monitor to 1280x1024, 60 hertz refresh
These are the settings of the monitor, HP Pavilion f1903
There is nothing on the screen but black and the message. Monitor
menu will not work so I have to boot to regular mode.
Also was getting a blue screen every once in awhile. Message on
screen disappears to fast to read but it is a driver problem. I did
have an Nvidea card installed and could not unistall the drivers
before I installed the Radeon. Have tried to manually remove all the
Nvidea drivers. I now have the Omega drivers for Ati cards installed.
Blue screen has not come up for a couple of days but still can not
boot to safe mode.
OS: XP pro, SP2
Pentium 4, 2.4 mH processor
ASUS P4SDX mainboard
Sound Blaster Extigy sound card
2 gig ram
2 SATA hard drives, SATA Plextor DVDR/CDR drive
3 External USB 2 hard drives
Sponsored Links
You need to go through Control Panel, Display to set the system display
properties to that which is acceptable to the Monitor itself.
Changing the properties via the monitor's on screen menu is not changing the
system properties.
> message:
> Out of range
> boot to safe mode.
> OS: XP pro, SP2
> 2 gig ram
Reply to bar
ATI has a removal tool on their website (I believe gets rid of anything ATI
related from your system) maybe Nvidea has something similar. You may wish
to remove the ATI software/drivers as well and reload it in vgamode.
Uninstall antivirus before removing and reinstalling ATI software (quote
from their website).
Pardon my ignorance, but what are Omega drivers? This is a built by ATI
card not powered by ATI, right?
r.
"Joe Tansey" <fillyflash@yahoo.com> wrote in message
news:6f83o0db917jduvdno0ucdud7os01epof4@4ax.com...
> message:
> Out of range
> boot to safe mode.
> OS: XP pro, SP2
> 2 gig ram
Reply to Anonymous
- 0 +
Nvidea drivers often uninstalled in add/remove dialogue
"namniar" <this@that> wrote in message
news:OchtXyWvEHA.2172@TK2MSFTNGP14.phx.gbl...
ATI
wish
> r.
> > message:
> > Out of range
> > boot to safe mode.
> > OS: XP pro, SP2
> > 2 gig ram
Reply to dl
Same with ATI. The utility I spoke of is for incomplete and/or problem
removals. I have personally never had to use it.
r.
"DL" <dl@spoofmail.nothere> wrote in message
news:OoY2QVZvEHA.3728@TK2MSFTNGP12.phx.gbl...
> ATI
> wish
>> r.
>> > message:
>> > Out of range
>> > boot to safe mode.
>> > OS: XP pro, SP2
>> > 2 gig ram
Reply to Anonymous
"Joe Tansey" <> wrote in message
To give you a chance to read the blue-screen error text, configure your
system to NOT reboot when a STOP error occurs.
Right-click on My Computer icon, select Properties, select Advanced and then
under "Startup and Recovery" click Settings. On the ensuing dialog box
untick "Automatically restart" and click OK.
This should give you chance to read the text next time an error occurs, and
with luck diagnose the cause.
Hope this helps.
Reply to Anonymous
Omega drivers at http://www.omegadrivers.net/
Supposed to be better drivers for ATI cards than ATI drivers.
>r.
>> ATI
>> wish
>>> r.
>>> > message:
>>> > Out of range
>>> > boot to safe mode.
>>> > OS: XP pro, SP2
>>> > 2 gig ram
Reply to Anonymous
Thanks Joe & Nathan
r.
"Nathan McNulty" <newsgroups@msn.com> wrote in message
news:%23Y5c0blvEHA.1404@TK2MSFTNGP11.phx.gbl...
> They are simply an enhanced version of the ATI drivers. ATI's drivers
> come out of the box for better synthetic benchmarking scores at the cost
> of image quality and is often limited in its options.
> The Omega Drivers have simply been edited to allow even laptops to use
> them and focuses more on quality of image and keeps the gamer in mind
> instead of some benchmark ;)
> Nathan McNulty
>>>r.
>>>>ATI
>>>>wish
>>>>>(quote
>>>>>ATI
>>>>>r.
>>>>>>message:
>>>>>>Out of range
>>>>>>boot to safe mode.
>>>>>>OS: XP pro, SP2
>>>>>>2 gig ram
Reply to Anonymous
There are 930 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
