Archived from groups: alt.comp.periphs.mainboard.gigabyte,alt.comp.periphs.mainboard.giga-byte (More info?)
I have a GA-7VT600-1394 motherboard. When I got the board, it had Bios rev.
F5 and everything worked seamlessly with no problems. About 3 months ago, I
flashed the bios to F7 to ensure large hard disk support and every since, at
every power up I get a bios error "Some bios settings have prevented the
system from booting, defaults have been loaded, F1 to continue, DEL for
Setup" and every time I go into the bios and do not change anything and save
+ exit and still at every power up I get the same error. I have reversed
back to bios F5, and tried F6 and back to F7 with no change. I have changed
from the Main bios to the Backup, re programmed both and still no change. I
have also taken all the memory out and tried them all one at a time and with
each stick I get the same error. I'm thinking it may be a memory issue
because I cannot run this ram at 400MHz without frequent system hangs,
crashes, memory cant be read errors and lockups so I keep the speed down to
333MHz. I also get the same crahses, etc @ 400MHz using one stick of this
ram at a time. I haven't tried any other memory as I don't have any to test
but I cant imagine that all 3 sticks are bad altho I have seen stranger
things. It boggles me that this didn't happen until I flashed the BIOS. I do
not overclock my system and no hardware other than a power supply upgrade
has been changed since the day I built the system. Once the system is on, it
will operate normally with the usual occasional lockups about once a month
or so depending on what I'm doing. Any information anyone could provide
would be greatly appreciated. Thanks for your time.
GA-7VT600-1394 Mobo
1.5GB Corsair Registered ECC DDR 3200+ (3x512MB CMX512RE-3200LLPT)
(More memory info: http://tinyurl.com/4nr5x)
ATI AIW 9800 Pro 128
36GB WDD SATA Raptor
120GB WDD SATA
120GB ATA133 External Firewire Seagate (used occasionally for backup
purposes only)
New 500W PSU
WinXP Pro SP2
A:\DOS\ver
MS-DOS version 2.11
A:\DOS\_
GA-7VT600-1394 Mobo
120GB WDD SATA
purposes only)
New 500W PSU
WinXP Pro SP2
A:\DOS\ver
MS-DOS version 2.11
A:\DOS\_
