Archived from groups: alt.comp.periphs.mainboard.giga-byte (More info?)
Hi all, I have just upgraded the motherboard in my PC and now I have a
problem. The system works fine apart from the fact that whenever I plug a
Sony digital camera (I haven't tried any other brands as I dont have access
to any, but I have tried 3 different model Sony camera) into any of the USB
ports, the computer will hardware reset.
I have tried messing with the bios settings but no luck. Any ideas?
The specs are as follows:
P4 2.66@533
Gigabyte 8IPE1000 rev 2
2x 512 Kingston 400mhz ram in dual channel
ATI Radeon 9650 128meg
480W power supply
U¿ytkownik "Dre" <blah@somewhere.com> napisa³ w wiadomo¶ci
news:432def5c$1@patrick.nettas.net...
> access
> USB
Have you reinstalled the system as well? Or are you using previous system
drivers, because such are probably needed for USB support.
What Windows version are you using?
"Robbo" <robbo@i.luv.spam.com> wrote in message
newsgob0s$kqv$1@atlantis.news.tpi.pl...
a
> > access
> > USB
> rgsd,
> rb
Sorry, should have mentioned the software. The system also got a new Sata
hard disc so total clean fresh install, no old software. The system is
running Windows 2000.
It gets better, I have just upgraded the other PC here to the same spec
motherboard, allthough with a 3.2gig processer over the 2.66gig. This
system works fine and I haven't done anything differently.
Also, whenever I use anything like Partion magic or say use Computer
management built into 2000, it resets whenever I try and change a drive
letter...
