Water cooling VS thermal load question
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I bought a water cooling setup for my computer, more for the
"geekiness" of it than anything else. Who wouldn't want to see green
water flowing inside a computer?
I'm not an overclocer, or pushing the envelope, but I wanted a
solution to the NOISE generated by all the fans required to cool a
prescott 2.8 P4. After installing it, and running it for a while, I
noticed something. Before, the idle temperature was X and the
load temperature was 15-25 degrees (F) above idle. Now, the
idle and load temperatures hardly move but a degree or two.
My thinking, is that with a stable temperature, wouldn't the stress
on the CPU be less than always jumping up and down?
Just wondering........
G
Guest
Guest
That's exactly what water cooling is all about. Lower temps and less stress
on the cooled parts = longer life.
But then, you would probably change the computer before the NORMAL temps
caused any problem anyway (-:
Regards:
Richard Urban
aka Crusty (-: Old B@stard :)
"p51d007" <p51d007@hotmail.com> wrote in message
news:htlso0tbr1pphd5kmb6fktp74o436ojpel@4ax.com...
G
Guest
Guest
p51d007 wrote <and I snipped>:
Yes, but the incremental stress caused by running apps on an otherwise
idle CPU is tiny compared with the thermal stress caused by booting up
a stone cold PC.
You can avoid that tiny stress by always running something at low priority.
I suggest downloading Prime95, to do something useful with your wasted CPU
cycles; get it at http://www.mersenne.org/freesoft.htm
Cheers, Bob
keith
1,335
I also run water cooling, my PC runs 24/7 and gets the occasional reboot for
software updates, etc. When not gaming or video editing, I run Folding@Home
and that keeps my cpu always "hot" in addition to helping find a cure for
cancer. As you noticed the temperature delta between idle and full load is
much less using water cooling. Not to mention quieter. If your delta is only
2 or 3 degrees above idle, that is fantastic and shows your cooling solution
is nowhere near it's heat saturation point. Crank that baby up on some sort
of distributed computing software and help humanity find prime numbers, look
for aliens, or cure cancer!
Blackwood Toyota Parts Dept.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.789 / Virus Database: 534 - Release Date: 11/7/2004
Andy
1,239
In article <eXLrw#ZxEHA.4044@tk2msftngp13.phx.gbl>, Keith
<ANTISPAMraptur@cox-internet.com> writes
<blah>
Do these water cooling kits really work then?
andy
G
Guest
Guest
Of course, that is the whole point of using them.
> <blah>
G
Guest
Guest
They cool to a baseline of room temperature.. they are quiet, but introduce
problems relating to placement of cooling pipes.. best probably used in a
largish case.. apparently the green fluid in clear pipes looks good when lit
by cold-cathode lighting.. obviously, a see through case or panel is
required to make the most of the view..
"andy" <andy@microshade.demon.co.uk> wrote in message
news:AQVfYCAavNkBNw$S@microshade.demon.co.uk...
>>for
>>Folding@Home
>>only
> <blah>
> andy
G
Guest
Guest
Yes, water cooling works and you can buy a kit that will fit
your CPU, graphics and RAM, even the hard drive. One reason
water cooling is better than air cooling is that air is an
insulator unless it is moving since it has a low specific
heat (the amount of heat calories) that still air can
absorb. Even when not being pumped, water absorbs a large
amount of heat and thus the CPU and other parts do not spike
in the same way an air-cooled machine can.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
I run Folding@Home
find a cure for
and full load is
your delta is only
| <blah>
| andy
G
Guest
Guest
Damn. I believe the question has already been answered if you will read the
posts just above yours!
Regards:
Richard Urban
>>for
>>Folding@Home
>>only
> <blah>
> andy
Andy
1,239
In article <eXtrRUoxEHA.1188@tk2msftngp13.phx.gbl>, Mike Hall
<mike.hall.mail@sympatico.ca> writes
And I thought they where just a geeky computer trip.
Think I might get one, especially if they're quieter
than the enormous fan I have in mine.
Thanks Mike.
All the best.
andy
