IBM Files Patent For Power Delivery via Heat Sink
illfindu
370
So clearly IBM is so much smarter then me its crazy but does any one else think its kinda a silly idea i mean electricity running through metal makes head and heat sinks are suppose to expel heat from the cpu heat. Im sure they can make it work but seems like a odd idea
tongouch
Don't aim for success if you want it; just do what you love and
believe in, and it will come naturally.
syrious1
164
I was thinking the same thing. doesn't this go against the purpose of a heatsink, which is to expell heat not conduct it into channels
InvalidError
[citation][nom]illfindu[/nom]So clearly IBM is so much smarter then me its crazy but does any one else think its kinda a silly idea i mean electricity running through metal makes head and heat sinks are suppose to expel heat from the cpu heat. Im sure they can make it work but seems like a odd idea[/citation]
Using the heatsink to provide DC ground makes perfect sense since the heatsink has a whole lot more metal and hence lower electrical resistivity and I2R losses than fine traces on the CPU die, solder balls, substrate, socket pins and PCB traces which could significantly reduce DC power losses there. This would make it possible to eliminate ground pins used mainly to provide DC ground but some ground pins would still be required for AC components that still require a low-impedance path with minimal loop surface area with power/IO traces to keep EMI and AC ripple on supply rails within tolerances.
Going beyond that to squeeze IO interfaces between heatsink fins/CPU however seems a little extreme and very inconvenient since it would require the use of complex heat-spreaders or sticking the CPU between a top and bottom substrate which would be problematic for heat flow. Integrating signal traces in grooves under the heatsink would require precision alignment with the CPU, which may be a little too much for DIY, it would also make usage of thermal paste a lot trickier.
So, I doubt using the heatsink as a signal carrier beyond complementary DC ground would be practical.
digiex
834
This will be good for embedded processors where the heat sink is permanently in place.
For removable heat sinks, a precise aligner is needed.
Netherscourge
390
Not very practical in a typical DESKTOP environment.
In a MOBILE/TABLET/LAPTOP/SMARTPHONE environment, where circuit board real estate is scarce, it's VERY practical.
Using a Heatsink as a conduit for the purpose of space-saving is quite genius to be honest. In fact, I'd go ahead and patent it's use as a data pathway also - because the smaller these devices get, the more creative/alternate routes become important.
madooo12
367
a heatsink is hot, it has a much higher resistance, so it would conduct electricity worse and generate less heat, maybe I'm missing something here
G
Guest
Guest
They should harness the energy from the heat output of today's CPUs and GPUs and power the rest of the system with it.
tntom
356
This hardly seems patentable especially since this has been done before. It is just a basic Conduit. Many amplifiers have routed wires through heatsinks. The manufacturing technology to do this on the nano scale might be patentable though.
ProDigit10
585
makes no sense, once you touch the fan you'll change cpu voltage. Static electricity could possibly knock out the cpu!
No thank you!
I much rather prefer the old ways.
G
Guest
Guest
The thermoelectric effect is the direct conversion of temperature differences to electric voltage and vice-versa. A thermoelectric device creates a voltage when there is a different temperature on each side. Conversely, when a voltage is applied to it, it creates a temperature difference. At the atomic scale, an applied temperature gradient causes charge carriers in the material to diffuse from the hot side to the cold side, similar to a classical gas that expands when heated; hence inducing a thermal current.
This effect can be used to generate electricity, measure temperature or change the temperature of objects. Because the direction of heating and cooling is determined by the polarity of the applied voltage, thermoelectric devices are efficient temperature controllers.
Heatsinks COULD BE USED to generate electricity and be used for cooling!
wiyosaya
915
Hmmm...peltier devices have been available for some time. I am almost willing to bet that someone could successfully challenge this patent. To me, this patent seems obvious and nothing new.
A Bad Day
2,256
[citation][nom]greghome[/nom]So.........we're getting porcupine inspired CPUs in the future because power will be delivered on both surfaces of the CPU die ? ......cool.....[/citation]
The only thing that's missing is data/power connections through the sides. Then it's a true porcupine stack of dies.
G
Guest
Guest
I know thermoelectric power generation is terribly inefficient, but it seems like it could be so useful to return 10% of the energy lost due to heat back into the system.
dgingeri
[citation][nom]shafe88[/nom]If IBM is going to bring this to the market, they better hope Intel brings back the Prescott core.[/citation]
Have you seen the power/heat numbers for the new Power7 chips? I think they resurrected the Prescott and gave it a new instruction set.
IBM:
Incompetent
Builders of
Malfunctions
jkflipflop98
[citation][nom]InvalidError[/nom]Using the heatsink to provide DC ground makes perfect sense since the heatsink has a whole lot more metal and hence lower electrical resistivity and I2R losses than fine traces on the CPU die, solder balls, substrate, socket pins and PCB traces which could significantly reduce DC power losses there. This would make it possible to eliminate ground pins used mainly to provide DC ground but some ground pins would still be required for AC components that still require a low-impedance path with minimal loop surface area with power/IO traces to keep EMI and AC ripple on supply rails within tolerances.Going beyond that to squeeze IO interfaces between heatsink fins/CPU however seems a little extreme and very inconvenient since it would require the use of complex heat-spreaders or sticking the CPU between a top and bottom substrate which would be problematic for heat flow. Integrating signal traces in grooves under the heatsink would require precision alignment with the CPU, which may be a little too much for DIY, it would also make usage of thermal paste a lot trickier.So, I doubt using the heatsink as a signal carrier beyond complementary DC ground would be practical.[/citation]
Wait, are you saying that electricity flows easier through an aluminum heatsink than through the copper ground wires built into the die? I assure you that's not the case.
chewy1963
246
I don't know why someone doesn't just make the CPU in the shape of a heat sink, that would be the end of the thermal paste industry! lol.
dgingeri
[citation][nom]jkflipflop98[/nom]Wait, are you saying that electricity flows easier through an aluminum heatsink than through the copper ground wires built into the die? I assure you that's not the case.[/citation]
Actually, if it's the 1um gold wires in the die, the .5mm gold contact area of the socket to the chip, or the
