Not seeing Wireless Connection in Network Connection
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have a Netgear wireless accesspoint connected to a highspeed cable internet
connection and my downstairs Windows XP PC. I wanted to be able to connect my
PC in an upstairs bedroom wirelessly.
I purchased a Netgear WG111 USB Wireless Adapter and installedthe software
for the the upstairs PC (runing XP Home edition). Netgear instructed me to
allow their software to install the device, not Microsoft. Everything
installed fine; I have a blue light on the USB Adapter (antenna) and the
Netgear software shows good signal strength. However, when I go to use
Internet Explorer, I can't connect to the internet.
I got on the phone with a Netgear tech who, after working for awhile, found
that in the Network Connections (in the Control Panel) that for some reason
the Wireless Network wasn't installed/visible. (FYI: My handheld connectects
to the WAP fine)
I uninstalled and re-installed as he instructed, but the result was the same.
FYI: I went to my office and installed the software on my XP PRO
workstation, and everything installed fine.
ANyone have any idea why the Wireless Network option isn't appearing in
Network Connections?
Thanks!
Matt
4 answers Last reply
More about wireless connection network connection
  1. Archived from groups: microsoft.public.windows.networking.wireless (More info?)
    Hi
    Quote: "I have a Netgear wireless accesspoint connected to a highspeed cable
    internet
    connection and my downstairs Windows XP PC".
    The above does not really describe your connection.
    Is it a Wireless Cable/DSL Router? or Just an Access Point connected to
    what?
    As for the Wireless itself may be this can Help.
    Wireless - Basic Configuration: http://www.ezlan.net/Wireless_Config.html
    Wireless Security - http://www.ezlan.net/Wireless_Security.html
    Jack (MVP-Networking).
    "motomanmatt" <motomanmatt@discussions.microsoft.com> wrote in message
    news:CD87C6A7-81EE-47EA-A541-640921655CF5@microsoft.com...
    internet
    my
    to
    found
    reason
    connectects
    > to the WAP fine)
    same.
    > Thanks!
    > Matt
  2. Archived from groups: microsoft.public.windows.networking.wireless (More info?)
    I receive my internet through a cable, the same cable that provides our
    television.. It terminates at a Motorola cable modem, which is in turn
    connected to a Netgear router. The router serves my downstairs PC, as well as
    my Netgear access point.
    Matt
    "Jack (MVP)" wrote:
    > Hi
    > internet
    > what?
    > internet
    > my
    > to
    > found
    > reason
    > connectects
    > > to the WAP fine)
    > same.
    > > Thanks!
    > > Matt
  3. Archived from groups: microsoft.public.windows.networking.wireless (More info?)
    > our television.. It terminates at a Motorola cable modem, which is
    > in turn connected to a Netgear router. The router serves my
    > downstairs PC, as well as my Netgear access point.
    > Matt
    > "Jack (MVP)" wrote:
    >> Hi
    >> to what?
    >> http://www.ezlan.net/Wireless_Config.html Wireless Security -
    >> message news:CD87C6A7-81EE-47EA-A541-640921655CF5@microsoft.com...
    >>> cable internet connection and my downstairs Windows XP PC. I wanted
    >>> to be able to connect my PC in an upstairs bedroom wirelessly.
    >>> software for the the upstairs PC (runing XP Home edition). Netgear
    >>> instructed me to allow their software to install the device, not
    >>> Microsoft. Everything installed fine; I have a blue light on the
    >>> USB Adapter (antenna) and the Netgear software shows good signal
    >>> strength. However, when I go to use Internet Explorer, I can't
    >>> awhile, found that in the Network Connections (in the Control
    >>> Panel) that for some reason the Wireless Network wasn't
    >>> installed/visible. (FYI: My handheld connectects to the WAP fine)
    >>> the same.
    >>> appearing in Network Connections?
    >>> Thanks!
    >>> Matt
    You have to deliberately set up a wireless connection. Try running the
    wireless connection setup wizard in Control Panel.
    Q
  4. Archived from groups: microsoft.public.windows.networking.wireless (More info?)
    > Matt
    Also make sure that Wireless Zero Configuration service is set to
    automatic startup and is started.
    Q
    > "Jack (MVP)" wrote:
    >> Hi
    >> to what?
    >>> the same.
    >>> Thanks!
    >>> Matt
Wireless Connection Netgear Wireless Networking
