Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hi All Again,
Just installed the motherboard in my system and when it boots up all i am
getting is the boot up sequence followed by 5 shortish beeps.
I have assertained that this is a cpu error, but i cant figure out why? I
do know that the motherboard is setup to auto detect the CPU but it keeps
getting it wrong, it keeps finding an AMD Athlon XP 1250 mhz. I have tried
all different types of configuration but it doesnt change.
On Thu, 12 Aug 2004 17:09:28 GMT, "Mag1c1an" <mag1c1an@ntlworld.com>
wrote:
>Hi All Again,
>Any help would be greatly appreciated.
>Flip The Little Dip switch on the board!!
Rotor:-
"rotor" <rotor@free.net> wrote in message
news:411beb49.5859156@news.btinternet.com...
> wrote:
> >Hi All Again,
I
tried
> Rotor:-
Thanks for that little diamond piece of information, as if i hadn't already
got the dip switches all set to the correct settings.
I have the clk_sw set to auto, not off which is the default, so it should
auto configure itself to 400/333/266 fsb, and i also have the multiplier
dips set to auto, so theoretically this should find the right processor.
But it still only finds it as a 1250 mhz, in actual fact it doesnt matter if
the clk_sw is off or on, it doesnt seem to make any difference, the cpu is
still only found as a 1250.
The trouble is the computer wont stay on long enough for me to get into the
bios to change the FSB to 166 through the settings, when ever i try to get
to the bios i get the 5 shortish beeps and the computer turns itself off.
Im losing my mind, any other constructive answers please!
rotor@free.net (rotor) wrote in message news:<411beb49.5859156@news.btinternet.com>...
> Rotor:-
I had the same thing, and as suggested above there is a small switch
on the motherboard which should be in the ON position (this is
supposed to be the default position according to the manual, but it
seems it's always set the other way). You may also need to set the FSB
in the BIOS to 166Mhz to get your CPU identified correctly.
"Mag1c1an" <Mag1c1an@magic.land> wrote in message news:<p9_Sc.29$l82.20@newsfe4-gui.ntli.net>...
Mmmm, sorry I suggested that too. Google Groups is so slow for seeing
posted answers.
That sounds like a dodgy board. If you don't go into BIOS will it
actually boot into the OS?
I Found this (for another Gigabyte board, but maybe of some help?)
"Award BIOS 4.51PG/Gigabyte GA-BX2000: Five short beeps sound when the
main BIOS is corrupted and the spare BIOS has to be loaded as only
choice for successful boot."
>> Rotor:-
>Dan
Well its a dodgy board then, if you tried the above settings!
Rotor!!
"Anders Nielsen" <Still@nomail.dk> wrote in message
news:kmorh0tldv1mava7pg4usg385f5vqfg2cf@4ax.com...
> On Fri, 13 Aug 2004 20:02:39 GMT, "Mag1c1an" <Mag1c1an@magic.land>
> wrote:
> >I have now decided that the board is at fault and it is now going back to
> >dabs on monday.
> What about the throttle option in the bios, is that enabled? if yes
> try disable it.
The board wont let me get into the bios, ive tried 3 different cpus now and
everytime i try to enter the setup the boot up just hangs and doesnt enter,
ive tried my 2600 xp that dabs sent me back as none faulty, ive tried a
2400xp that im running in this machine which works, and that does the same
thing, and ive tried a 900 mhz duron, all the same.
HEY, got a new idea, what video card you got in there??? Manual says
"Caution:AGP 2X is not supported by nVidia... etc.... you might expirience
system unable to boot... etc" Ya right on the first page...also this has a
dual bios in it (backup bios)
KK
news:q2pTc.2001$TS.1660@newsfe3-gui.ntli.net...
to
> > >dabs on monday.
> > try disable it.
and
enter,
> Wont let me enter the bios.
