High speed device plugged into non-high speed port
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I've been having this problem for several weeks and can't seem to fix
it.
I have a DFI Ultra Infinity motherboard, Athlon XP 2500, Windows XP.
The motherboard has six onboard USB 2.0 ports that work fine.
I added a four port VIA VT6202 PCI USB 2.0 card about six months ago,
and it worked fine. I then bought another VIA VT6202 PCI USB 2.0 card,
as I needed more USB ports, only this card had a slightly different
number on the VT6202 chip (after the VT6202 there is another number on
each chip). The new card only worked at USB 1.0, and every time I
plugged in a USB device, it would say "High speed device plugged into
non-high speed port" and suggest I plug the device into one of the
ports in bold type that can support a hi speed device.
I think it's possible that the old card's drivers are still in the
system, and have automatically installed themselves for the new VT6202
card, which is a different make, and that may be why it isn't working.
http://www.geocities.com/usbproblems/usbproblem3.jpg
In this picture the first device is the motherboard's USB, with four
external hard drives plugged into it, and the second is one of the PCI
cards.
http://www.geocities.com/usbproblems/usbproblem4.jpg
This picture shows one of the PCI cards, but none of the connected
devices are showing that they are connected, even though they are, and
they are accessible.
http://www.geocities.com/usbproblems/usbproblem5.jpg
This picture shows the USB devices in Device Manager.
I have had SP1 installed since it came out, and have just upgraded to
SP2, but with no luck.
I've taken out the two VIA PCI cards, and put in two NEC based ones,
and they have exactly the same problem. They come up with the same
message about a non-high speed port, so I'm not sure what's going
wrong.
Does anybody have any ideas what I should try? I've checked all the
drivers for the USB cards, and uninstalled and then reinstalled them
from the supplied driver CDs, but that hasn't worked.
7 answers Last reply
More about high speed device plugged high speed port
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    See:
    http://support.microsoft.com/default.aspx?scid=kb;en-us;312370
    Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
    www.coribright.com
    "James Jones" <jamesjones@124.com> wrote in message
    news:68f87779.0411281400.7d40d167@posting.google.com...
    > it.
    > cards.
    > wrong.
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    "Cari \(MS-MVP\)" <Newsgroups1@coribright.com> wrote in message news:<uL6lcPa1EHA.1292@TK2MSFTNGP10.phx.gbl>...
    > See:
    > www.coribright.com
    Thanks for that, but I've already visited that site, but I don't think
    it applies to my system, as I've got all the XP updates installed.
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I have another problem with my USB 2.0 cards. I've tried updating the
    drivers with the ones that came on the CDs with the cards, but it says
    "The specified location does not contain information about your
    hardware". I'm definitely using the correct drivers, for an NEC 720101
    USB card.
    I'm reaching the point where I think I'm going to have to reinstall
    Windows XP completely from scratch, in order to get these to work, but
    I have so many applications installed that it will take me at least
    five hours to install of them, so that's really a last resort for me.
    Does anybody know how to remove all of the USB drivers that are
    installed on my system, and start installing the correct ones from
    scratch?
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Sorry to bump this message again, but I've searched all over usenet
    for a solution to this problem, and none of the threads have an
    answer. (Most of them don't have any responses at all, just the
    original poster saying he had the same problem as me, and no replies).
    I'm sure it must be a matter of simply uninstalling or deleting USB
    driver files, and then reinstalling them, but could anybody tell me
    what files I should delete? I've done an Automated System Restore, so
    it doesn't matter too much if I accidentally delete the wrong files, I
    can always restore my system in about ten minutes.
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi RC, thanks for that, but there are no other USB entries hiding
    anywhere in Device Manager. I'm going to try removing the drivers that
    Dev.Man. says are loaded for the cards manuall, by moving them from
    the Windows folder and putting them on a different drive, with a
    different name. I'm pretty sure that the original drivers from my
    first USB 2.0 card are lurking around in my Windows directory
    somewhere, and are automatically being loaded when I try to uninstall
    and reinstall the NEC USB cards.
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    A further update:
    In Device Manager, my two NEC USB 2.0 cards come up as "NEC PCI to USB
    Open Host Controller", and "USB 2.0 Root Hub".
    The drivers that are installed for "NEC PCI to USB Open Host
    Controller" are as follows:
    Windows\system32\drivers\usbhub.sys
    Windows\system32\drivers\usbohci.sys (not a typo, ohci, not ehci)
    Windows\system32\drivers\usbport.sys
    Windows\system32\usbui.dll
    They all say:
    Provider: Microsoft Corporation
    File version: 5.1.2600.2180(xpsp_sp2_rtm.040803-2158)
    But the drivers on the CD that came with the PCI cards are:
    Setup.exe
    ousb2.inf
    ousb2hub.sys
    ousbehci.sys
    but I can't get them to install. I've tried reinstalling the drivers,
    using the CD, but it just says "The specified location does not
    contain information about your hardware", so maybe Windows has
    installed the wrong drivers (its own) for these two cards?
    Does anybody know how to fix this problem?
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi RC, well, it's get curioser and curioser!
    I previously had my four external hard drives plugged into the four
    motherboard's USB 2.0 ports, and the following plugged into the NEC
    USB cards' ports: Laser printer, colour printer, external DVD writer,
    digital camera, and MP3 player.
    The external DVD writer often came up with the 'high speed device'
    message, and the MP3 player too, but now the DVD writer is working at
    USB 2.0 speed, so I thought I'd plug the external hard drives into the
    NEC cards' ports, and they are also working at USB 2.0! The only
    devices that come up with the message now are my two MP3 players - one
    is a 'Neo' MP3 player that I bought from Ebay, and is definitely USB
    2.0, and the other is a Netac iMuz. Both of these still bring up the
    'high speed into non-high speed' message, even when I plug them into
    the motherboard's USB ports.
    So I think it's something very odd to do with the MP3 players' USB
    compatibility - I'm going to check the CD that came with each of them
    to see if there are any drivers on there, but they both said they
    didn't need drivers for XP.
    As I type I'm transferring 10 gigs of files from one of the external
    hard drives to another, using the NEC cards ports, and it's only
    taking about six minutes to do this, so the cards are definitely
    working okay now. I checked what drivers were installed, and they are
    the same as the ones you listed, so that parts all okay too now.
    (Perhaps I couldn't install the ones that came on the driver CD with
    the NEC cards any more because the SP2 ones had taken precedence over
    them, and were better matches, according to XP?)
    If it's only the MP3 players that are causing this problem, it's not
    worth me worrying about it any more, as I only transfer a few files a
    week, if that.
USB Devices Windows XP
