ISA Sound Card
Add a reply
 Word :   Username :
Bottom
Author
 Thread : ISA Sound Card
Profile: stranger
More Information
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hello all,
I have an ISA slot sound card Creative Labs CT2800 Vibra16s installed on an
older machine with originally win98 upgraded to XPpro. I cannot get any
sound. All audio codexes and drivers seems to be fine except an error that
tells me there is no mixer installed. I downloaded and tried to install the
drivers for this card but the error said they are 16bit applications and may
harm the system. Is this card too old for XP or am I missing something.
Thanks for Any Responses
Related Pr oduct
More Information
Yes, you are missing the beauty of a $399 P4 Dell. Your old
system is not worth spending money for upgrades.
But you might check your mobo mfg'r and Creative Labs for
info on the problem. I would suggest that you use the
device manager to remove the sound card and see if it will
properly install as a clean install, rather than an upgrade.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"Parker" <nospam@nospam.com> wrote in message
news:euzcVXy1EHA.3452@TK2MSFTNGP14.phx.gbl...
| Hello all,
cannot get any
missing something.
Profile: stranger
More Information
Parker wrote:
> Hello all,
using a win98 or worse still...a 16 bit driver
is (as you can see) not likely to work with XP.
from the control panel...
completely uninstall the card and see if XP picks it up and installs
it upon reboot...
XP actually does support quite a few ISA devices.
if you have no luck...you can get a new pci sound card for as little as
$15 or so
More Information
Have you tried the drivers included with XP? I believe that you'll have to
use the hardware installation wizard to install them manually. I think that
XP won't autodetect ISA devices, even those of the PnP sorts. (I haven't
done that with a Vibra 16, but I have used a PnP ISA modem, and a legacy ISA
SCSI controller. Both worked.)
Try the Soundblaster 16/ Awe32 WDM drivers.
Better yet, if you have a free PCI slot, try a cheap PCI sound card.
Address scrambled. Replace nkbob with bobkn.
> Hello all,
> an older machine with originally win98 upgraded to XPpro. I cannot get
> any sound. All audio codexes and drivers seems to be fine except an error
> that tells me there is no mixer installed. I downloaded and tried to
> install the drivers for this card but the error said they are 16bit
> applications and may harm the system. Is this card too old for XP or am I
> missing something.
Profile: stranger
More Information
Thank You all for the reponses. I'd rather just put the cheap sound card in
and forget it.
> Hello all,
> missing something.
Add a reply
Google Ads
News
Creative Finally Launches True X-Fi PCI Express Parts
Published on May 19, 2008
  It took some time, but Creative Labs has finally introduced decent sound cards for PCI Express interface. Read more
Crucial launches Radeon X850 XT graphics card
Published on March 09, 2005
Crucial, mainly known for performance system memory modules, today announced a new high-end graphics card. Read more
CES 2007: Asus shows off external graphics for notebooks
Published on January 07, 2007
Asus's big product at CES Unveiled was their XG Station, an external graphics solution which turns a run-of-the-mill notebook into a gaming machine. Read more
SanDisk intros 512 MByte micro SD card
Published on July 13, 2005
Samsung claims it is first to offer a 512 MByte microSD card. Read more
Latest Reviews & Articles
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
