Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Having issues using onboard sound+sound card
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have been using onboard sound (AC97) for a few months without a problem.
Yesterday, I picked up a sound card and installed it, wanting to have both
the onboard and the sound card work at the same time. I'm currently doing
this type of thing on another PC I have.
However, when I install the PCI card, my onboard sound is no longer
accessible, even though its still listed as Enabled in the BIOS. When I
remove/uninstall the PCI card, the onboard shows up again and works again.
It seems that I can only have 1 sound source on my PC! However, I have both
of them setup fine on my other PC.
Both PCs are running WinXP Pro with SP2 and all major updates done.
The PC with the problem is:
AMD Athlon64
1024 PC3200 ram
Asus K8VSE Delux motherboard
the new PCI card being installed is a C-Media card, very basic.
I have searched all over and cannot find a way to get it to work. Is there
some sort of flag/setting I need to do to allow me to use two sound sources
at once??
Many many thanks!
Sponsored Links
Contact manufacturer - maybe if the board detects a pci soundcard the
onboard is automatically disabled.
r.
"PeterB" <PeterB@discussions.microsoft.com> wrote in message
news:342D2C61-50A4-46FA-820B-593123D606A4@microsoft.com...
> both
> AMD Athlon64
> 1024 PC3200 ram
> there
> sources
> at once??
> Many many thanks!
Reply to Anonymous
- 0 +
I combed through the site and didnt find anything. I sent them an email with
the problem already and still no response. I'll check again.
Thanks for the response
> r.
> > both
> > AMD Athlon64
> > 1024 PC3200 ram
> > there
> > sources
> > at once??
> > Many many thanks!
Reply to peterb
There are 1031 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
