Archived from groups: microsoft.public.windowsxp.hardware (More info?)
After installing SP 2 on my XP pro machine I cannot write to DVDs.
I can read DVDs, read and write CDs but when I try to write to DVD
I get a "Please insert disk" message.
Roxio's ECDC is installed, version 5.3.5 - and I read somewhere that SP2
blocks the roxio drivers. All I want to do is burn a system restore DVD for
backup purposes for the system, but when I use MS backup I get the same
"insert disk" message. I could buy new burning software but am wondering
if that would solve the problem or if there is a cheaper way to solve this.
Look for updates at the Roxio website.
Cari (MS-MVP) Windows Client - Printing/Imaging and Hardware
www.coribright.com
"Bob" <bob(remove)@boblane.com> wrote in message
news:%23t%239zOu2EHA.4004@tk2msftngp13.phx.gbl...
> for
> this.
> Thanks,
> Bob
for
this.
| Thanks,
| Bob
Hi Bob -
In addition to Cari's advice to look for updates, you may need to uninstall,
reboot and reinstall your Roxio software.
Thanks for the replies:
I did check for updates and do have the latest roxio updates for version 5.
I also got a hotfix from ms and installed it; and then
I just tried a demo of the newest Nero software and it too reports no disk
when I try to write to a DVD! That fact leads me to wonder about a reinstall
of roxio since Nero should have installed its own drivers, and still the
problem persists.
Further suggestions?
Bob
"Jef Norton" <jefn_REMOVE_YOUR_SHORTS_@sbcglobal.net> wrote in message
news:XwIsd.38956$6q2.21814@newssvr14.news.prodigy.com...
> SP2
> for
> this.
> | Thanks,
> | Bob
> Hi Bob -
> uninstall,
> Jef
"Bob" <bob(remove)@boblane.com> wrote in message news:<#HdQW4v2EHA.824@TK2MSFTNGP11.phx.gbl>...
> problem persists.
> Bob
> SP2
> for
> this.
> > | Thanks,
> > | Bob
> > Hi Bob -
> > uninstall,
> > Jef
Yes, I am trying to complete a system backup using a DVD and
a floppy with Windows Automatic System Restore.
Bob
"abrams" <abram@mailinator.com> wrote in message
news:9e34cc48.0412051841.75420a76@posting.google.com...
> It may be a hardware problem with your DVD writer.
> Are you trying to make Windows Backup write to a DVD disk, by
> selecting the drive letter as a backup destination?
> http://www.firestreamer.com - NTBACKUP to DVD and DV
>> 5.
>> disk
>> reinstall
>> problem persists.
>> Bob
>> SP2
>> > DVD
>> for
>> > same
>> > wondering
>> this.
>> > | Thanks,
>> > | Bob
>> > Hi Bob -
>> > uninstall,
>> > Jef
I think your last reply gave all of us the answer..
You can write to the CD/DVD otherwise, correct? Meaning if you
write an individual file or folder to the CD/DVD using Roxio or
Nero, this gives you no problem?
Answer inline - at the bottom of the thread (snipped and copied below):
> All I want to do is burn a system restore DVD for backup purposes
> for the system, but when I use MS backup I get the same "insert disk"
> message.
> version 5. I also got a hotfix from ms and installed it; and then
> no disk when I try to write to a DVD! That fact leads me to wonder
> about a reinstall of roxio since Nero should have installed its own
> drivers, and still the problem persists.
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
You may want to consider using http://www.firestreamer.com/fsdvd/. It
allows Windows Backup to write ASR backups directly to DVD with
compression and media spanning.
Bob (remove) wrote:
> Thanks for the response. The odd thing is I did a backup to a DVD+RW
BEFORE
> installing SP2 and it worked just fine. The problem persists:
> I can read/write to CDs
> I can play pre-recorded DVDs
> I cannot write to any DVD "Please insert disk" error message.
Hi Bob.
I am having the exact same problem with DVD-RW. I can read DVD and CD roms
and write to CD-r/RW, but when it comes to DVD-R, DVD+R, and DVD-RW I get an
error message.
Did you have any success?
Thanks.
Brad
> Thanks,
> Bob
