G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Ok, I searched Google Groups for the answer *before* posting, so I
appologize if it has been answered before.
I recently built an Athlon 64 3200+ system using a Giga-Byte K8VT800M
motherboard and a Casedge minitower with front audio jacks. The audio cable
jacks are labled:
Audio:
HPOUT L
HPOUT-L
HPOUT R
HPOUT-R
GROUND
Mic:
MIC IN
MIC GRD
MIC POWER
Motherboard Pinout:
1 MIC
2 GRD
3 REF
4 Power
5 Front Audio (R)
6 Rear Audio (R)
7 Reserved
8 No Pin
9 Front Audio (L)
10 Front Audio (L)
I know I need to remove the jumpers on 5-6 and 9-10, but where do I plug the
front audio header cables from there?
jacks are labled:
Audio:
HPOUT L
HPOUT-L
HPOUT R
HPOUT-R
GROUND
Mic:
MIC IN
MIC GRD
MIC POWER
Motherboard Pinout:
1 MIC
2 GRD
3 REF
4 Power
5 Front Audio (R)
6 Rear Audio (R)
7 Reserved
8 No Pin
9 Front Audio (L)
10 Front Audio (L)
