USB power
Forum Motherboards & Memory : Gigabyte - USB power
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I'm running a GA-8IPE1000 Pro3 (latest BIOS, for whatever that's worth)
Is there any way to turn off the power to these external devices when
the system is powered off?
I've got a few accessories that light up when they detect power coming
from the USB ports, and a USB external hard drive which runs from the
USB port's power. All these accessories stay running after the system
powers down.
I've tried turning off the option to power the system on from the
keyboard, I can't think of anything else which might be relevant.
Anyone have any suggestions?
Sticks and stones may break my bones, but whips and chains excite me.
Sponsored Links
On Fri, 29 Oct 2004 03:55:10 -0600, DevilsPGD <devilspgd@crazyhat.net>
>powers down.
I switch the power off to the machine using the switch on the PSU.
Don't think there is any other way.
Reply to Anonymous
what i do is switch the psu power off, hit the power button on the case...
this pushes all the power out of the circuits... then u can turn the psu
back on...
u dig?
james.
"Edward W. Thompson" <thomeduk1@btopenworld.com> wrote in message
news:i7a6o0t2ku5fs1pc4t23k1klj9ivqolcbv@4ax.com...
> >powers down.
Reply to Anonymous
> back on...
> u dig?
I've done that on a number of cases, but as soon as the power supply's
always-on +5VDC rail comes on, the USB power returns.
The only thing I can think of would be to put in a PCI USB card, I've
got a spare one that provides it's power from a +5VDC floppy connector,
but that seems like such a waste.
FWIW, I'm not actually drawing power from the USB ports, I have an
external powered USB HUB which successfully turns on and off based on
whether the PC is providing power. I have confirmed the same occurs
from the motherboard's USB ports directly though, so bypassing the USB
hub isn't a workaround.
Hey, it's the female man.
-- Bart Simpson
Reply to Anonymous
if you are XP look here
http://www.procat.com/Winner/tips/ [...] power.html I got win 2k pro
and the same option is there , it is not checked by default. If you got
Linux there is a stand alone routine to control it but i forget where
Jim.
"DevilsPGD" <devilspgd@crazyhat.net> wrote in message
news:10oajko89ocvt83@news.supernews.com...
case...
> > back on...
> > u dig?
> -- Bart Simpson
Reply to Jim
Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > USB power
There are 1025 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
