Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Have two hard drives in my system. Both 80gb. I have deleted literally
everything off the slave drive except a Powerquest backup file which is
shown as 22,647,168 KB. When I check the properties of both hard drives the
slave shows 76.6GB and free space of 6.68GB !!! There are no partitions on
either disks. The only slightly odd thing I have done is make the master
disk my "D" drive and the slave "C". Can't think this can have any bearing
on this odd problem though.
I have emptied the normal recycle bin, (am using Norton's Protected recycle
bin).
"John Lowe" <john@johnlowe.co.uk> wrote in message
news:31s6c1F3bt0kpU1@individual.net...
the
recycle
> bin).
> Any ideas???
> Many thanks, John Lowe UK
Your post is a little puzzling. You say "There are no partitions on
either disk", but you also say that you have deleted everthing
except for the PowerQuest backup file. The two statements are
contradictory: Either you have some partitions (with some files),
or you have no partitions (in which case you have no files at all.
I suspect that you do have a partition on each disk. I also
suspect that you have some hidden folders. Did you tick
the box that makes Explorer show hidden and system files?
Please clarify. You should also state what tools you use to
determine the amount of used space and free space.
the
recycle
| bin).
| Any ideas???
SequoiaView is an excellent free (and clean) utility helpful in tracking
down mysterious missing drive space.
It provides a one window graphical representation of which files are taking
up how much space where on a drive, often quickly and easily tracking down
files that Windows is reluctant to reveal.
I'm not an MVP a VIP nor do I have ESP.
I was just trying to help.
Please use your own best judgment before implementing any suggestions or
advice herein.
No warranty is expressed or implied.
Your mileage may vary.
See store for details.
You need at least ONE partition on each drive in order to store files.
Emptied your Norton Protected ecycle bin files???
> the slave shows 76.6GB and free space of 6.68GB !!! There are no
> partitions on either disks. The only slightly odd thing I have done is
> make the master disk my "D" drive and the slave "C". Can't think this can
> have any bearing on this odd problem though.
> recycle bin).
> Any ideas???
Both disks are setup as a "single" drive, that is, not partitioned into
several "drives" as per PartitionMagic etc.
Disk D has WINXP and all my programmes on it and Disk C, the slave disk, has
absolutely nothing except the Powerquest backup file, when viewed in
Explorer. "My Computer" confirms the free space as 6.68GB. Hidden folders is
checked to show them.
WINXP was loaded on to the slave disk prior to me installing it on the other
disk and then making it a slave, if you follow.Hence it is still shown as
Drive "C". I installed WINXP on the other disk, an IBM Deskstar, as I
believed the original "C" drive, now the slave, might have developed some
bad sectors.( Phew this is complicated...can't blame you if you don't follow
and switch off!).
All very strange. I intend to format the slave disk and presumably that will
free up the whole 80gb!!
"Pegasus (MVP)" <I.can@fly.com> wrote in message
news:eVAMeuk3EHA.2624@TK2MSFTNGP11.phx.gbl...
This means that each disk as one partition!
news:31u7t6F3gmjdaU1@individual.net...
has
is
other
follow
> and switch off!).
will
