Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Installing Hardware Problems
Forum Windows XP : Windows XP General Discussion - Installing Hardware Problems
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I am performing an OS change from Win98 SE to WinXP Pro SP2. I am having
two hardware problems I have not been able to resolve on my own or with an
internet search.
Hopefully somebody can help me.
The first one is that the program wants to install a multimedia controller.
I am not sure what Windows thinks it is finding.
PCI Slot 2 (PCI bus 0, device 16, function 0)
This device is not configured correctly. (Code 1)
To reinstall the drivers for this device, click Reinstall Driver.
Device Instance Id:
PCI\VEN_1105&DEV_8300&SUBSYS_00000000&REV_02\2&EBB567F&0&80
Hardware lds: PCI\VEN_1105&DEV_8300&SUBSYS_00000000&REV_02
PCI\VEN_1105&DEV_8300&REV_02
PCI\VEN_1105&DEV_8300&CC_048000
Compatible Lds: PCI\VEN_1105&DEV_8300&CC_048000
PCI\VEN_1105
PCI\CC_048000
PCI\CC_0480
Current Power State: D3
Power Capabilities: PDCAP_D0_SUPPORTED
PDCAP_D3_SUPPORTED
Power State Mappings: S0->D0
S1->Unspecified
S2->Unspecified
S3->D3
S4->D3
S5->D3
Hopefully from the above somebody can give me some ideas regarding this
multimedia controller WinXP is trying to install.
The big problem is I can not get my Nvidia based FX 5200 video controller to
install.
Currently: VGA Controller (VGA Compatible)
PCI bus 1, device 0, function 0
Device Instance Id:
PCI\VEN_10DE&DEV_0322&SUBSYS_00000000&REV_A1\3&27528C43&1&0008
Hardware lds: PCI\VEN_10DE&DEV_0322&SUBSYS_00000000&REV_A1
PCI\VEN_10DE&DEV_0322&REV_A1
PCI\VEN_10DE&DEV_0322&CC_030000
Compatible lds: PCI\VEN_10DE&CC_030000
PCI\VEN_10DE
PCI\CC_030000
PCI\CC_0300
PDCAP_D3_SUPPORTED
S1->Unspecified
S2->Unspecified
S3->D3
S4->D3
S5->D3
When I try to install the drivers for the FX5200 there appears there may be
a resource conflict between the video card and the VIA CPU To AGP
Controller.
The computer is an older 800 Mhz Pentium III Micron Millennia with 512 megs
of memory.
I know this is a lot of information and probably not the right information.
I would sure appreciate some guidance in how I can over come these hardware
conflicts.
<Bill>
Brought to you from beautiful Unalaska/Dutch Harbor, Alaska.
N 53° 51.140' W 166° 30.228' (WGS 84)
Sponsored Links
Before you insta;;ed XP did you run the Upgrade Advisor? It would have given
you a list of incompatible hardware and software.
A multimedia controller could be a sound card device. Did you update your
soundcard with XP drivers? Same for the video card.
Try booting into Safe Mode and see if there are multiple errors in Device
Manager. Remove all duplicates and/or error indicating devices and boot
again to see if XP will 'fix' the errors.
"Bill Bradshaw" <bradshaw@arctic.net> wrote in message
news:%23bJB0Pv3EHA.524@TK2MSFTNGP09.phx.gbl...
>internet search.
> controller. I am not sure what Windows thinks it is finding.
> Device Instance Id:
> PCI\VEN_1105
> PCI\CC_048000
> PCI\CC_0480
> PDCAP_D3_SUPPORTED
> S1->Unspecified
> S2->Unspecified
> S3->D3
> S4->D3
> S5->D3
> to install.
> Device Instance Id:
> PCI\VEN_10DE
> PCI\CC_030000
> PCI\CC_0300
> PDCAP_D3_SUPPORTED
> S1->Unspecified
> S2->Unspecified
> S3->D3
> S4->D3
> S5->D3
> be a resource conflict between the video card and the VIA CPU To AGP
> Controller.
> megs of memory.
> information. I would sure appreciate some guidance in how I can over come
> these hardware conflicts.
> <Bill>
Reply to Jerry
I did run upgrade advisor and did not receive any incompatible hardware or
software errors. I should have stated I am doing a clean install and not an
upgrade from Win98 SE.
The sound is 128 Voice PCI Waveable Onboard Sound.
Name Creative AudioPCI (ES1371,ES1373) (WDM)
Manufacturer Creative Technology Ltd.
Status OK
PNP Device ID PCI\VEN_1274&DEV_1371&SUBSYS_18541042&REV_08\2&EBB567F&0&70
I/O Port 0x0000E800-0x0000E83F
IRQ Channel IRQ 10
Driver c:\windows\system32\drivers\es1371mp.sys (5.1.3612.0 built by:
WinDDK, 39.88 KB (40,832 bytes), 12/9/2004 9:52 AM)
Conflicts/Sharing
I/O Port 0x000003C0-0x000003DF VgaSave
I/O Port 0x000003C0-0x000003DF VIA CPU to AGP Controller
IRQ 10 Creative AudioPCI (ES1371,ES1373) (WDM)
IRQ 10 U.S. Robotics 56K Faxmodem Win 1806
IRQ 10 ALi PCI to USB Open Host Controller
IRQ 11 Multimedia Controller
IRQ 11 ALi PCI to USB Open Host Controller
IRQ 11 U.S. Robotics 56K Fax PCI
IRQ 9 VIA Rev 5 or later USB Universal Host Controller
IRQ 9 Standard Enhanced PCI to USB Host Controller
Memory Address 0xCF400-0xEFFFF PCI bus
Memory Address 0xCF400-0xEFFFF Motherboard resources
Memory Address 0xD0000000-0xD7FFFFFF VIA CPU to AGP Controller
Memory Address 0xD0000000-0xD7FFFFFF Video Controller (VGA Compatible)
Memory Address 0xA0000-0xBFFFF VgaSave
Memory Address 0xA0000-0xBFFFF VIA CPU to AGP Controller
I/O Port 0x000003B0-0x000003BB VgaSave
I/O Port 0x000003B0-0x000003BB VIA CPU to AGP Controller
Memory Address 0xDC000000-0xDDFFFFFF VIA CPU to AGP Controller
Memory Address 0xDC000000-0xDDFFFFFF Video Controller (VGA Compatible)
I will give it ago and report back.
<Bill>
> have given you a list of incompatible hardware and software.
> your soundcard with XP drivers? Same for the video card.
> Device Manager. Remove all duplicates and/or error indicating devices
> and boot again to see if XP will 'fix' the errors.
Reply to Anonymous
Seems like if you are doing a clean install, you didnt delete partition that
contained previous system. There should be no sharing conflicts this way.
Delete partition, reformat unpartitioned space to NTFS and install Windows
XP. XP should have all the drivers for an older system, if not you certainly
should be able to add them after OS install. Good Luck!
> Status OK
> IRQ Channel IRQ 10
> Conflicts/Sharing
> <Bill>
Reply to Anonymous
Jerry, I resolved the multimedia controller problem but I still can not get
the Nvidia FX5200 video card to install. I have XP drivers for it that I
can install under safe mode but do not work when I boot into XP. XP wants
to put my video card into VGA compatible mode with an error mark. Any other
suggestions?
<Bill>
Reply to Anonymous
I formatted the harddisk. That had to clean it. I have resolved my
multimedia card issues but I still have not been able to get the video card
to install.
<Bill>
> partition that contained previous system. There should be no sharing
> conflicts this way. Delete partition, reformat unpartitioned space to
> NTFS and install Windows XP. XP should have all the drivers for an
> older system, if not you certainly should be able to add them after
>> hardware or software errors. I should have stated I am doing a
>> clean install and not an upgrade from Win98 SE.
Reply to Anonymous
There are 1229 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
