Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have a Sharp Camera/Camcorder and I am trying to add the driver from a CD
that came with the device.
I can not figure out how to add the driver!
I plug the camera in to the USB and XP does not recognize the hardware.
I am sure I am doing something wrong.
What are the steps to accomplish this?
Unplug the camera from the USB port.
Use add/remove hardware to remove the camera.
You might need to go as far as using the device manager to
remove all the USB ports and rebooting.
Then insert the CD in the drive and if it does not auto-run
the install or setup, browse the CD to find a setup,
install. It will help to read the manual that came with the
camera (or download the instructions).
After the software/drivers are installed, turn the camera ON
and then as the last thing, plug the USB in to the USB port.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"Jack Barrett" <jack4450@frontiernet.net> wrote in message
news:uBpWWO33EHA.404@TK2MSFTNGP10.phx.gbl...
driver from a CD
the hardware.
| Thanks in advance,
| Jack Barrett
| My Web Site: http://windsurf_2.tripod.com |
If the CD does not autorun, which I assume it doesn't, there is likely
to be a Setup.exe file either in the root directory or in a sensibly
named subdirectory. Failing this, when XP finds the hardware and wants
to search for drivers, tell it specifically to include the CD in the
search. Failing both of the above, contact Sharp!
On Sat, 11 Dec 2004 06:21:25 -0500, "Jack Barrett"
>Thanks in advance,
>Jack Barrett
>My Web Site: http://windsurf_2.tripod.com >
Please respond to the Newsgroup, so that others may benefit from the exchange.
Peter R. Fletcher
message news:uBpWWO33EHA.404@TK2MSFTNGP10.phx.gbl...
> Thanks in advance,
> Jack Barrett
