Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > Problem with GA-8IPE1000 and CPU FAN
Forum Motherboards & Memory : Gigabyte - Problem with GA-8IPE1000 and CPU FAN
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
As I use my computer under high stress, the processor temperature rises
rapidly – yet, the CPU fan does not increase in RPM as the temps rise.
I am running a P4 3E – idle temp is around 40c however, with 5 minutes
of playing a game (or something requiring substantial processing power)
I am looking at 60c.
However, the CPU fan remains at a constant 2600 RPM. It has the ability
to run at 5000 RPM. Is there any way of correcting this problem?
when I get the comp it working good but now it can't go over 2600
egyteam
Sponsored Links
On Sun, 12 Dec 2004 05:41:43 +0000, egyteam
Check the Bios settings
Should either be flat or intelgent control, these is a setting in the bios
for this..
Unless its a Intel fan that has Temp control..
Reply to Anonymous
There are 1311 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
