Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA-7N400 Pro2 Rev 1 SATA Problem
Forum Motherboards & Memory : Gigabyte - GA-7N400 Pro2 Rev 1 SATA Problem
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I was successfully running a single WD 36GB 10k RPM SATA drive as the boot
disk (set to "BASE" ) on my GA-7N400 Pro2 board (Rev 1) for several months.
Then it started to get flakey recognizing the drive when booting. Would take
a couple of reboots to get past detecting the drive and on to booting.
Finally, Windows 2000 started getting errors when accessing the disk and the
system would crash.
I RMA'ed the disk back to WD. It was returned as "recertified" but is still
not recognized by the board. I suspect that the SATA controller has a
problem, but I have no other SATA drives to test with. I am on F5 and
briefly loaded F11 to no avail.
Has anyone else had an experience similar to mine? Any ideas on a fix?
John Bissell
Sponsored Links
"John Bissell" <bissell@nospam.alum.mit.edu> wrote in message
news:E0Hxd.4225$9j5.3940@newsread3.news.pas.earthlink.net...
take
the
> system would crash.
still
> John Bissell
Since the drive is ok, whats left?
cables-remove and replace
driver-reinstall
BIOS -reflash
Board - Go to the ver-2.
HG
Reply to Anonymous
> take
> the
> system would crash.
> still
Had the same problem,
It was the motherboard fcuk SATA channel
Reply to Anonymous
There are 523 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
