Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
New SATA power connector was design to support 3.3V power (no HD available
yet).
Other than that it delivers same power (amps and volts) to you HD.
Some HD brands have both power connectors (old 4 pin Molex and new SATA),
others have just new SATA.
e.g. new Maxtor 300Gb has only new SATA power connector, but their 200Gb
has both.
Slowly all new HD will have SATA connector ONLY.
Now back to your case. If your HD has both connector, you can use ether one.
It makes no DIFFERENCE.
If you have HD with only SATA power connecter and your power supply doesn't
have one then buy Molex to SATA adapter (some retail box HD include it)
Hope it cleared some confusion.
"keisuke" <keisuke@discussions.microsoft.com> wrote in message
news:A94DE59F-48CD-4681-877E-D27B193B1596@microsoft.com...
> yesyes, i understand that i shouldn't plug both at the same time.. sorry i
> didn't explain my question well. and yes, there are both slots on my
maxtor
> SATA..
> so what would happen if i instead use the regular connector on my maxtor
> SATA that has the regular power connector slot? would my drive be slower
or
> have any other effects because the SATA power connector might have more
power
> than the regular one (otherwise, why did they even make a SATA power
> connector if the regular one works?), or would it be like andrew E. said,
> that either would be recommended? thanks.
