Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > Problems with SPB Pocket 2.1?
Archived from groups: microsoft.public.pocketpc (More info?)
I had Pocket Plus 2.0 installed on my Asus A716 and noticed that 2.1 was
just released. After installing it I noticed that my tabs are gone.
Actually it looks more like they are being covered up by the section above
it in the Today screen. Has anyone run across this problem? I'm wondering
if it is conflicting with something else.
Sponsored Links
I just installed the update from 2.0 to 2.1, over the existing 2.0, with no
problems. All of my tabs are intact. Maybe you could check the settings
and height in pixels to change the display area? I am using a Dell Axim
x3i.
"Cold War Relic" <Cold_War_Relic@SPAMIAMinsightbb.com> wrote in message
news:Xns9522E5C6C154Dcoldwarrelicinsightb@63.240.76.16...
wondering
Reply to Anonymous
CORRECTION: I also have SBSH Calendar Plus Pro installed and it is THAT
program where I can change the display pixel height. Sorry for the mix-up.
"Shawn E. Hale" <SEHaleNOSPAM1@comcast.net> wrote in message
news:ufhJjY0ZEHA.3012@tk2msftngp13.phx.gbl...
no
> x3i.
above
> wondering
Reply to Anonymous
news:e8Qjwi0ZEHA.3112@TK2MSFTNGP09.phx.gbl:
> THAT program where I can change the display pixel height. Sorry for
> the mix-up.
>> with
> no
>> settings and height in pixels to change the display area? I am using
>> a Dell Axim x3i.
>> message news:Xns9522E5C6C154Dcoldwarrelicinsightb@63.240.76.16...
>> > 2.1 was just released. After installing it I noticed that my tabs
>> > are gone. Actually it looks more like they are being covered up by
>> > the section
> above
>> wondering
I appreciate the response very much. I have emailed SPB's tech support
and hopefully they will have a solution. Otherwise I will probably just
do a hard reset and reinstall everything.
CWR
Reply to Anonymous
I had a problem upgrading to 2.0 and I received a reply from tech support
within 24 hours. There was a remnant left over during the upgrade and they
told me what to delete. Pretty good help. Obviously put off the hard reset
as long as you can. Post back when resolved. Good luck.
news:Xns95237E38FD86Dcoldwarrelicinsightb@204.127.199.17...
> > the mix-up.
> >> with
> > no
> >> a Dell Axim x3i.
> >> > the section
> > above
> >> wondering
> CWR
Reply to Anonymous
news:uTN4Xt3ZEHA.1048@tk2msftngp13.phx.gbl:
> support within 24 hours. There was a remnant left over during the
> upgrade and they told me what to delete. Pretty good help. Obviously
> put off the hard reset as long as you can. Post back when resolved.
> Good luck.
> message news:Xns95237E38FD86Dcoldwarrelicinsightb@204.127.199.17...
>> > for the mix-up.
>> >> 2.0, with
>> > no
>> >> using a Dell Axim x3i.
>> >> > tabs are gone. Actually it looks more like they are being
>> > above
>> >> > I'm
>> >> wondering
>> support and hopefully they will have a solution. Otherwise I will
>> probably just do a hard reset and reinstall everything.
>> CWR
There was another guy on the Pocket PC Addict forum with the same
problem. Going back to the original 2.0 solved the problem for him so I
gave it a shot. Sure enough, it fixed the tabs issue. I'm still curious
as to what SPB has to say.
Dean
Reply to Anonymous
- 0 +
I've had the same problem with PocketPlus since the original v2.0 came out,
ad now with 2.1 - and Spb Tech Support has been totally unresponsive.
I can't save images or web pages at all, even though they claim PocketPlus
adds this functionality.
Whenever I try to save either an image file or an entire web page, I get the
same error message: "Failed to retrieve the file".
I have NEVER seen this "feature" work
news:uTN4Xt3ZEHA.1048@tk2msftngp13.phx.gbl...
they
reset
Reply to johnm
There are 1177 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
