Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA-8ISXT-FS floppy problem
Forum Motherboards & Memory : Gigabyte - GA-8ISXT-FS floppy problem
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I am trying to set up this system with a GA-8ISXT-FS motherboard. Everything
is working fine except the floppy drive. I tried 3 different known working
drives and cables. The drive light goes on but it cannot read any disk. No
flags in Device Manager. It will not boot from a floppy so it is not just
Windows. It says no system disk if I try to boot from a floppy. In Windows,
it asks for a disk even though one is in there. The disks work when checked
on other systems. Every drive and cable came from a working system. The
cables are indexed, so I know they are not backwards. No bent over pins
either. I think the controller might be gone. Any other ideas?
Sponsored Links
"kazikmazik" <kazhatespam@wideopenwest.com> wrote in message
news:RIqdnexMV5eShGrcRVn-pA@wideopenwest.com...
Everything
Windows,
checked
I realized the only component I did not check was the power connector. I
tried the other power connector and it now works. I don't know how the drive
light worked before since this would indicate the drive was getting power.
Sorry for the false alarm.
Reply to Anonymous
news:wKmdndUVItKhP2rcRVn-vg@wideopenwest.com...
> Everything
>> working
>> No
> Windows,
> checked
> drive
You might've been using a fan power connector.
Reply to Anonymous
There are 1298 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
