G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
The book says I can use either the front sound connections or the back sound
connections... Does that mean that once I remove the jumpers and plug in my
connections to the front of the case that the rear case ones are disabled?
OR does it mean I can choose to use either at any time? How about both?
Thanks in advance. - Dud
