Problem with Cd-RW Drive
Forum Windows XP : Windows XP General Discussion - Problem with Cd-RW Drive
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
For the first time since i got my machine two years ago, my cd Drive won't
read blank cd's. I have in the past recorded all kinds of stuff on cd's with
the same drive. It recognizes that a Cd-R is in, but won't give me any
options and says "D:\ is not accessible, Incorrect function" when i double
click the icon. It reads all other types of discs just fine. It's like it
doesn't know what to do with a blank anymore. What should I do? Is it
something i can fix at home? Are my settings just off little?
Soccer
Sponsored Links
In Windows Explorer, right-click the drive letter and click
PROPERTIES|RECORD tab, and verify that recording is enabled. If it is
not, check the box.
For most XP answers and tweaks...
http://www.kellys-korner-xp.com/xp_abc.htm
http://dougknox.com http://aumha.org
http://support.microsoft.com
Reply to Dev
> not, check the box.
I can't find that tab. For some reason it says that my drive type is "CD
Drive" and not CD-RW (thats what it is). Is that part of the problem?
Reply to Anonymous
>>not, check the box.
Sounds plausible to me...
http://kadaitcha.cx/cdr_cdrw.html
Reply to Dev
I have a similar problem. Whenever I put in any kind of burned or burnable CD
I get an error saying: D:\ (OR E:) is not accessible. Incorrect function.
I’ve looked over the website/forums and have tried everything that seemed
like it might help. And I’ve had no luck what so ever. Will you help me fix
this problem? Otherwise I’m going to have to do a clean XP Pro install with
no backups. Thank you
-Chaz
Reply to Anonymous
First, are you sure that the problem is with Xp and not the CD-RW drive?
How old is the drive? You may want to replace the CD-RW drive, since they
are most affordable now and it is a lot faster to replace the drive than it
is to reinstall XP.
"Chaz" <Chaz@discussions.microsoft.com> wrote in message
news:EFFF2E92-3DD4-4C23-8C21-E1D5B1B74330@microsoft.com...
>CD
> I've looked over the website/forums and have tried everything that seemed
> like it might help. And I've had no luck what so ever. Will you help me
> fix
> this problem? Otherwise I'm going to have to do a clean XP Pro install
> with
> -Chaz
Reply to Anonymous
Yes, I'm positive that the problem is XP, I only started having this problem
after I upgraded to SP2. And both of my drives are only like a half of a
year old. So I see no reason to buy new ones. Any other sugestions?
> is to reinstall XP.
> >CD
> > fix
> > with
> > -Chaz
Reply to Anonymous
i have a similar problem too.whenever i put blank cd its always says that,no
cd/dvd drives have been detected or there are no item on the cd or device..
this has never been a problem before.i usually burn cds. and its quite fine.
but now i don't.i cannot store,create music files from my cd drive.. and
also,on my cd drive the USED SPACE is 0 bytes (all shaded blue color)and the
FREE SPACE also 0 bytes too. my OS is win xp home. (2yrs. now) please help
me to fix this problem . THANKS IN ADVANCE
mjnhez
> > is to reinstall XP.
> > >CD
> > > fix
> > > with
> > > -Chaz
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problem with Cd-RW Drive
There are 1316 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
