After Power down from WinXP Pro Computer Will Not Power Up
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have built and upgraded quite a number of PCs in the IBM ATX
architecture.
Today, I moved the internals of a computer that has been successfully
running Windows XP Pro for 2-1/2 years. That computer's internals include
an ASUS P3V4X Motherboard, 3 ATA-100 hard drives (all controlled by an
ATA/100 Promise PCI controller,) a CD-RW drive, 3 CD-ROM drives, a 3COM NIC,
a SoundBlaster PCI card, an AGP video card, and a 3 1/2" floppy drive.
After transferring all internals from my old cabinet to a new one, I powered
the computer up. It booted and started WindowsXP Pro successfully, though
prior to starting Windows XP Pro, the motherboard boot process indicated
that a problem existed with the floppy drive, which I bypassed by pressing
F1. The problem was easy enough to diagnose; somehow the power cable for
the floppy disk drive had come loose from its connector/socket. After WinXP
Pro finished its startup process successfully, I exited Windows by selecting
Start | Power Off | Power Off. The computer powered down normally.
After disconnecting the power cord from the back of the computer, I replaced
the power cable on the floppy drive's power connector. Then, I plugged the
power cord into the back of the computer and pressed the Power button.
However, nothing happened. I checked to be sure that the small wire from
the Power button was still plugged into the proper location on the
motherboard. It was. Nevertheless, the computer will not boot up.
For the moment, I'm not sure what's wrong. I don't know if the 300 Watt
power supply just happened to become defective at that time, or if something
is wrong with the motherboard.
So, I shall greatly appreciate your kind help in figuring out what's wrong.
With kindest regards,
Dick Smith
SmithRMS@Comcast.net
18 answers Last reply
More about after power winxp computer power
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    When you unplugged the power cord from the power supply, is
    it possible you tripped a circuit break, voltage switch or a
    fuse?
    Are you sure the wall socket is powered,too?
    If you have a multimeter, check the PSU voltages.
    The people think the Constitution protects their rights;
    But government sees it as an obstacle to be overcome.
    "AA Smith" <SmithRMS@Comcast.net> wrote in message
    news:ePd8bvv7EHA.2452@TK2MSFTNGP14.phx.gbl...
    ATX
    | architecture.
    successfully
    internals include
    controlled by an
    drives, a 3COM NIC,
    floppy drive.
    new one, I powered
    process indicated
    power cable for
    normally.
    Then, I plugged the
    Power button.
    small wire from
    location on the
    boot up.
    if the 300 Watt
    out what's wrong.
    | Dick Smith
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi, Jim!
    Thanks for your feedback. I sincerely appreciate your interest.
    The wall socket is definitely powered.
    I am not aware of any circuit breaker or fuse in the 300-watt power supply.
    There is a red volt setting switch; it's set to 115. If there's a fuse or
    circuit breaker of some sort on the ASUS P3V4X motherboard, I'm not aware of
    it.
    Dick Smith
    "Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote in message
    news:OwoY70v7EHA.3596@TK2MSFTNGP12.phx.gbl...
    > fuse?
    > ATX
    > | architecture.
    > successfully
    > internals include
    > controlled by an
    > drives, a 3COM NIC,
    > floppy drive.
    > new one, I powered
    > process indicated
    > power cable for
    > normally.
    > Then, I plugged the
    > Power button.
    > small wire from
    > location on the
    > boot up.
    > if the 300 Watt
    > out what's wrong.
    > | Dick Smith
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hello, again, Jim;
    I forgot to mention that I don't have a multimeter or volt meter of any
    kind.
    Dick Smith
    > fuse?
    > ATX
    > | architecture.
    > successfully
    > internals include
    > controlled by an
    > drives, a 3COM NIC,
    > floppy drive.
    > new one, I powered
    > process indicated
    > power cable for
    > normally.
    > Then, I plugged the
    > Power button.
    > small wire from
    > location on the
    > boot up.
    > if the 300 Watt
    > out what's wrong.
    > | Dick Smith
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Don't change the subject line, put the questions and answers
    in the body, please.
    PSU do have internal circuit protection, if you're sure the
    wall outlet has power and nothing happens when you press the
    power switch, some failure, perhaps a fuse, broken wire or
    such is the likely problem.
    Do any fans or lights work? Any beeps?
    You can buy a simple tester/meter for the power supply for
    $10-20, it might be a good investment and it can be used to
    check many other things too. Radio Shack has a nice little
    book on how to use a multimeter Google for "multimeter book
    radio shack" or "how to use a multimeter."
    news:ePhWUIw7EHA.3908@TK2MSFTNGP12.phx.gbl...
    | Hello, again, Jim;
    meter of any
    | kind.
    | Dick Smith
    in message
    is
    or a
    | > fuse?
    IBM
    | > ATX
    | > | architecture.
    been
    | > successfully
    computer's
    | > internals include
    | > controlled by an
    CD-ROM
    | > drives, a 3COM NIC,
    1/2"
    | > floppy drive.
    to a
    | > new one, I powered
    | > process indicated
    the
    | > power cable for
    exited
    down
    | > normally.
    the
    | > Then, I plugged the
    the
    | > Power button.
    the
    | > small wire from
    | > location on the
    not
    | > boot up.
    know
    | > if the 300 Watt
    figuring
    | > out what's wrong.
    | > | Dick Smith
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hello, again, Jim,
    Nothing happens when I press the Power button; no fans, no beeps, nothing
    whatsoever.
    I will pickup a tester at Radio Shack today.
    I don't understand the initials "PSU". What do they stand for?
    Dick Smith
    news:utz6hyx7EHA.3616@TK2MSFTNGP11.phx.gbl...
    > | Hello, again, Jim;
    > meter of any
    > | kind.
    > | Dick Smith
    > in message
    > is
    > or a
    > | > fuse?
    > IBM
    > | > ATX
    > | > | architecture.
    > been
    > | > successfully
    > computer's
    > | > internals include
    > | > controlled by an
    > CD-ROM
    > | > drives, a 3COM NIC,
    > 1/2"
    > | > floppy drive.
    > to a
    > | > new one, I powered
    > | > process indicated
    > the
    > | > power cable for
    > exited
    > down
    > | > normally.
    > the
    > | > Then, I plugged the
    > the
    > | > Power button.
    > the
    > | > small wire from
    > | > location on the
    > not
    > | > boot up.
    > know
    > | > if the 300 Watt
    > figuring
    > | > out what's wrong.
    > | > | Dick Smith
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Try the simple first.
    It was working before and you only switched the floppy cable.
    Perhaps you pulled or bumped a wire lose from the motherboard connections.
    Like the ........Power button wiring to the motherboard........Check all
    your connections.
    > architecture.
    > Dick Smith
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Thanks stonekeyboards for your feedback.
    I have double-checked all wiring connections to th motherboard; all are
    properly connected, including the Power Switch connector and the ATX Power
    supply connection to the ASUS P3V4X motherboard.
    Dick Smith
    "stonekeyboards" <stonekeyboards@discussions.microsoft.com> wrote in message
    news:DC217BF7-DB7A-4965-B278-FC279EB7EA47@microsoft.com...
    > your connections.
    >> architecture.
    >> include
    >> NIC,
    >> powered
    >> though
    >> pressing
    >> WinXP
    >> selecting
    >> replaced
    >> the
    >> something
    >> wrong.
    >> Dick Smith
  8. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    shorthand for power supply unit
    mobo motherboard
    news:OLplkRy7EHA.1296@TK2MSFTNGP10.phx.gbl...
    | Hello, again, Jim,
    beeps, nothing
    | whatsoever.
    stand for?
    | Dick Smith
    in message
    answers
    the
    the
    or
    for
    to
    little
    book
    | > | Hello, again, Jim;
    volt
    | > meter of any
    | > | kind.
    | > | Dick Smith
    wrote
    | > in message
    supply,
    | > is
    switch
    | > or a
    | > | > fuse?
    rights;
    overcome.
    the
    | > IBM
    | > | > ATX
    | > | > | architecture.
    has
    | > been
    | > | > successfully
    | > computer's
    | > | > internals include
    (all
    | > | > controlled by an
    | > CD-ROM
    | > | > drives, a 3COM NIC,
    | > 1/2"
    | > | > floppy drive.
    cabinet
    | > to a
    | > | > new one, I powered
    Pro
    boot
    | > | > process indicated
    which I
    somehow
    | > the
    | > | > power cable for
    | > exited
    powered
    | > down
    | > | > normally.
    of
    | > the
    connector.
    | > | > Then, I plugged the
    pressed
    | > the
    | > | > Power button.
    that
    | > the
    | > | > small wire from
    | > | > location on the
    will
    | > not
    | > | > boot up.
    don't
    | > know
    | > | > if the 300 Watt
    that
    | > figuring
    | > | > out what's wrong.
    | > | > | Dick Smith
  9. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hello, again, Jim;
    This problem just gets curioser and curioser. I have double-checked all
    wiring connections to the motherboard; all are properly connected, including
    the Power Switch connector and the ATX Power supply connection to the ASUS
    P3V4X motherboard.
    I took your suggestion on getting the RS Multimeter. However, the folks
    there were not aware of the How to Use book that you mentioned. So, I
    checked Google and found guidelines for testing the 300 watt ATX Power
    Supply. With the AC power cord from the wall socket plugged into the ATX
    Power Supply, I set the Multimeter to 15 volts DC (the lowest setting
    available on this Multimeter. I then used the black probe to probe one of
    the black wires in an unused power connector coming from the power supply.
    I used the red probe to probe the yellow wire in the power connector. I got
    no reading at all. I then used the red probe to probe the red wire socket
    on the power connector. Again, I got no reading. Incidentally, I did
    install a good AAA battery in the Multimeter before getting started.
    According to the guidelines I found on the article, that meant that the
    power supply was dead and needed replacement.
    So, I replaced it with as 400 watt, unswitched power supply and made all of
    the appropriate connections to the motherboard and floppy drive, hard drives
    and CD-ROMs
    However, the computer still wouldn't start. Absolutely nothing happens
    when I press the power button. No beep, no fans whirring, no lights flash.
    Nada!
    So I used the Multimeter to probe the 400 watt power supply's power
    connector's black, yellow, and red wires with the Multimeter set to 15 DCV.
    However, the needle did not budge from zero. It produced no reading
    whatsoever.
    Though it may be the case, I find it hard to believe that both power
    supply's are defective.
    I shall very greatly appreciate ay further ideas as to what might be keeping
    this computer from starting.
    Dick Smith
    > | Hello, again, Jim;
    > meter of any
    > | kind.
    > | Dick Smith
    > in message
    > is
    > or a
    > | > fuse?
    > IBM
    > | > ATX
    > | > | architecture.
    > been
    > | > successfully
    > computer's
    > | > internals include
    > | > controlled by an
    > CD-ROM
    > | > drives, a 3COM NIC,
    > 1/2"
    > | > floppy drive.
    > to a
    > | > new one, I powered
    > | > process indicated
    > the
    > | > power cable for
    > exited
    > down
    > | > normally.
    > the
    > | > Then, I plugged the
    > the
    > | > Power button.
    > the
    > | > small wire from
    > | > location on the
    > not
    > | > boot up.
    > know
    > | > if the 300 Watt
    > figuring
    > | > out what's wrong.
    > | > | Dick Smith
  10. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    You need to have a resistor/jumper to "turn the PSU ON"
    before it will provide voltage to the system.
    You do need to be sure that you're making metal to metal
    commotions inside the connectors.
    I will be busy with the New Year celebrations, so take your
    time, read the instructions and be careful not to damage
    your hardware or injure yourself.
    I would suggest that you double check everything, from using
    the meter on a 120 volt setting to check that the power cord
    is making power avail;able to the PSU and then check on each
    connector for rated voltage.
    Just be careful.
    news:ufPXJP37EHA.1204@TK2MSFTNGP10.phx.gbl...
    | Hello, again, Jim;
    double-checked all
    | P3V4X motherboard.
    However, the folks
    mentioned. So, I
    watt ATX Power
    lowest setting
    to probe one of
    the power supply.
    connector. I got
    red wire socket
    Incidentally, I did
    getting started.
    meant that the
    drive, hard drives
    | and CD-ROMs
    nothing happens
    no lights flash.
    | Nada!
    supply's power
    no reading
    | whatsoever.
    both power
    | Dick Smith
    in message
    answers
    the
    the
    or
    for
    to
    little
    book
    | > | Hello, again, Jim;
    volt
    | > meter of any
    | > | kind.
    | > | Dick Smith
    wrote
    | > in message
    supply,
    | > is
    switch
    | > or a
    | > | > fuse?
    rights;
    overcome.
    the
    | > IBM
    | > | > ATX
    | > | > | architecture.
    has
    | > been
    | > | > successfully
    | > computer's
    | > | > internals include
    (all
    | > | > controlled by an
    | > CD-ROM
    | > | > drives, a 3COM NIC,
    | > 1/2"
    | > | > floppy drive.
    cabinet
    | > to a
    | > | > new one, I powered
    Pro
    boot
    | > | > process indicated
    which I
    somehow
    | > the
    | > | > power cable for
    | > exited
    powered
    | > down
    | > | > normally.
    of
    | > the
    connector.
    | > | > Then, I plugged the
    pressed
    | > the
    | > | > Power button.
    that
    | > the
    | > | > small wire from
    | > | > location on the
    will
    | > not
    | > | > boot up.
    don't
    | > know
    | > | > if the 300 Watt
    that
    | > figuring
    | > | > out what's wrong.
    | > | > | Dick Smith
  11. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Thanks, again, Jim! I greatly appreciate your help.
    Where and how would I place a jumper to turn the PSU ON? The Power Switch?
    I'll try the tests again and be sure to make metal-to-metal contact with the
    Multimeter.
    Are you suggesting that I probe the female socket on the power cord with the
    Multimeter set on 120 volts DC while the power cord is plugged into the wall
    socket?
    The settings on the dial for this Multimeter are limited to 15 volts, 150
    volts, and 500 volts. The same holds true for AC voltage settings on the
    Multimeter dial.
    Dick Smith
    news:%23Ffifn37EHA.1392@tk2msftngp13.phx.gbl...
    > Just be careful.
    > | Hello, again, Jim;
    > double-checked all
    > | P3V4X motherboard.
    > However, the folks
    > mentioned. So, I
    > watt ATX Power
    > lowest setting
    > to probe one of
    > the power supply.
    > connector. I got
    > red wire socket
    > Incidentally, I did
    > getting started.
    > meant that the
    > drive, hard drives
    > | and CD-ROMs
    > nothing happens
    > no lights flash.
    > | Nada!
    > supply's power
    > no reading
    > | whatsoever.
    > both power
    > | Dick Smith
    > in message
    > answers
    > the
    > the
    > or
    > for
    > to
    > little
    > book
    > | > | Hello, again, Jim;
    > volt
    > | > meter of any
    > | > | kind.
    > | > | Dick Smith
    > wrote
    > | > in message
    > supply,
    > | > is
    > switch
    > | > or a
    > | > | > fuse?
    > rights;
    > overcome.
    > the
    > | > IBM
    > | > | > ATX
    > | > | > | architecture.
    > has
    > | > been
    > | > | > successfully
    > | > computer's
    > | > | > internals include
    > (all
    > | > | > controlled by an
    > | > CD-ROM
    > | > | > drives, a 3COM NIC,
    > 3
    > | > 1/2"
    > | > | > floppy drive.
    > cabinet
    > | > to a
    > | > | > new one, I powered
    > Pro
    > boot
    > | > | > process indicated
    > which I
    > somehow
    > | > the
    > | > | > power cable for
    > | > exited
    > powered
    > | > down
    > | > | > normally.
    > of
    > | > the
    > connector.
    > | > | > Then, I plugged the
    > pressed
    > | > the
    > | > | > Power button.
    > that
    > | > the
    > | > | > small wire from
    > | > | > location on the
    > will
    > | > not
    > | > | > boot up.
    > don't
    > | > know
    > | > | > if the 300 Watt
    > that
    > | > figuring
    > | > | > out what's wrong.
    > | > | > | Dick Smith
  12. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > Hello, again, Jim;
    > all wiring connections to the motherboard; all are properly connected,
    > including the Power Switch connector and the ATX Power supply
    > folks there were not aware of the How to Use book that you mentioned.
    > So, I checked Google and found guidelines for testing the 300 watt ATX
    > Power Supply. With the AC power cord from the wall socket plugged
    > into the ATX Power Supply, I set the Multimeter to 15 volts DC (the
    > lowest setting available on this Multimeter. I then used the black
    > probe to probe one of the black wires in an unused power connector
    > coming from the power supply. I used the red probe to probe the yellow
    > wire in the power connector. I got no reading at all. I then used
    > the red probe to probe the red wire socket on the power connector.
    > Again, I got no reading. Incidentally, I did install a good AAA
    > the power supply was dead and needed replacement.
    > all of the appropriate connections to the motherboard and floppy
    > drive, hard drives and CD-ROMs
    > happens when I press the power button. No beep, no fans whirring, no
    > lights flash. Nada!
    > DCV. However, the needle did not budge from zero. It produced no
    > reading whatsoever.
    Me too, though it could be so. You did have the meter set to read DC
    voltages, not AC or Resistance? I've done that more times than I would
    care to admit.
    Also, the little black switch on the back of the PSU, if it has one as
    most new ones do, is ON not OFF I guess. I've done that too.
    > keeping this computer from starting.
    > Dick Smith
    >> | Hello, again, Jim;
    >> meter of any
    >> | kind.
    >> | Dick Smith
    >> in message
    >> is
    >> or a
    >> | > fuse?
    >> IBM
    >> | > ATX
    >> | > | architecture.
    >> been
    >> | > successfully
    >> computer's
    >> | > internals include
    >> | > controlled by an
    >> CD-ROM
    >> | > drives, a 3COM NIC,
    >> 1/2"
    >> | > floppy drive.
    >> to a
    >> | > new one, I powered
    >> | > process indicated
    >> the
    >> | > power cable for
    >> exited
    >> down
    >> | > normally.
    >> the
    >> | > Then, I plugged the
    >> the
    >> | > Power button.
    >> the
    >> | > small wire from
    >> | > location on the
    >> not
    >> | > boot up.
    >> know
    >> | > if the 300 Watt
    >> figuring
    >> | > out what's wrong.
    >> | > | Dick Smith
  13. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi, Jack! Thanks for your interest.
    Yes I did have the Multimeter set to 15 volts DC (DCV). My 300 watt power
    supply has a switch on the back with off & on symbols O and I. I can never
    remember which is off and which is on, so I tried it on both settings. The
    400 watt PSU does not have a switch on the back other than the one that
    selects voltage, which is set to 115.
    This really is strange.
    Dick Smith
    "Jack Gillis" <XXXXXXXX@widomaker.com> wrote in message
    news:10tbes5llohnace@corp.supernews.com...
    >> Hello, again, Jim;
    >> including the Power Switch connector and the ATX Power supply connection
    >> of the black wires in an unused power connector coming from the power
    >> supply. I used the red probe to probe the yellow wire in the power
    >> connector. I got no reading at all. I then used the red probe to probe
    >> the red wire socket on the power connector. Again, I got no reading.
    >> Incidentally, I did install a good AAA battery in the Multimeter before
    >> getting started.
    >> of the appropriate connections to the motherboard and floppy drive, hard
    >> drives and CD-ROMs
    >> flash. Nada!
    >> DCV. However, the needle did not budge from zero. It produced no reading
    >> whatsoever.
    > care to admit.
    >> Dick Smith
    >>> | Hello, again, Jim;
    >>> meter of any
    >>> | kind.
    >>> | Dick Smith
    >>> in message
    >>> is
    >>> or a
    >>> | > fuse?
    >>> IBM
    >>> | > ATX
    >>> | > | architecture.
    >>> been
    >>> | > successfully
    >>> computer's
    >>> | > internals include
    >>> | > controlled by an
    >>> CD-ROM
    >>> | > drives, a 3COM NIC,
    >>> 1/2"
    >>> | > floppy drive.
    >>> to a
    >>> | > new one, I powered
    >>> | > process indicated
    >>> the
    >>> | > power cable for
    >>> exited
    >>> down
    >>> | > normally.
    >>> the
    >>> | > Then, I plugged the
    >>> the
    >>> | > Power button.
    >>> the
    >>> | > small wire from
    >>> | > location on the
    >>> not
    >>> | > boot up.
    >>> know
    >>> | > if the 300 Watt
    >>> figuring
    >>> | > out what's wrong.
    >>> | > | Dick Smith
  14. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    On Thu, 30 Dec 2004 23:44:36 -0600, "AA Smith" <SmithRMS@Comcast.net>
    >architecture.
    Try unplugging the power cable to the floppy power connector, and see
    if the computer goes on.
  15. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    On Fri, 31 Dec 2004 14:03:28 -0600, "AA Smith" <SmithRMS@Comcast.net>
    wrote:
    >Hello, again, Jim;
    >P3V4X motherboard.
    >and CD-ROMs
    >Nada!
    >whatsoever.
    The first thing you should check is the standby voltage, 5Vsb. Without
    it, the motherboard won't be able to turn on the power supply. If it's
    +5 volts, which I'm guessing it is, then check power supply on, PS-On,
    while you depress the case power button. PS-On should have positive
    voltage (2 - 5 volts) when the computer is off, and be at ground (less
    than 0.8 volts) when the case power button is depressed and when the
    computer is running. If PS-On goes to ground when the case power
    button is depressed, but the power supply does not run, then one or
    more of the power supply outputs is probably shorted to ground.
  16. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Check the motherboard mountings to the chassis don't include any 'spare'
    supporters. These spare standoffs must be removed if they are the bare metal
    types, since only one can short out a track on the motherboard, and the PC
    will behave exactly as you describe, nothing happens.
    >architecture.
    > NIC, a SoundBlaster PCI card, an AGP video card, and a 3 1/2" floppy
    > drive.
    > powered the computer up. It booted and started WindowsXP Pro
    > successfully, though prior to starting Windows XP Pro, the motherboard
    > boot process indicated that a problem existed with the floppy drive, which
    > I bypassed by pressing F1. The problem was easy enough to diagnose;
    > somehow the power cable for the floppy disk drive had come loose from its
    > connector/socket. After WinXP Pro finished its startup process
    > successfully, I exited Windows by selecting Start | Power Off | Power
    > replaced the power cable on the floppy drive's power connector. Then, I
    > plugged the power cord into the back of the computer and pressed the Power
    > button. However, nothing happened. I checked to be sure that the small
    > wire from the Power button was still plugged into the proper location on
    > the motherboard. It was. Nevertheless, the computer will not boot up.
    > something is wrong with the motherboard.
    > wrong.
    > Dick Smith
  17. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi, Gary! Happy New Year!
    Sorry I haven't gotten back to you folks sooner. Last night was quite a
    to-do here and I'm just getting going today.
    The problem is solved thanks to the generous help of those in this newsgroup
    that have taken an interest. I wound up removing the power supply to one
    component at a time, starting with the floppy, and checking to see if the
    PSU would start the computer after each removal. After everything was
    removed and still no perceptible juice came forth from the PSU, I removed
    the motherboard to check its mountings as you had suggested. I then found a
    screw laying under the mobo in such a way that it had to press against the
    mobo when it was mounted. Oddly enough, I couldn't visually detect any
    damage to the mobo. So, I removed the screw, remounted the mobo and hooked
    everything back up. When I pressed the Power button, the computer started
    and seems to run ok. So, I guess the screw did no permanent damage.
    Thanks again for your kind and generous help. I sincerely appreciate it.
    Dick Smith
    "Gary" <cc@dd.com> wrote in message
    news:eZbV%23N47EHA.2196@TK2MSFTNGP11.phx.gbl...
    > metal types, since only one can short out a track on the motherboard, and
    > the PC will behave exactly as you describe, nothing happens.
    >>architecture.
    >> include an ASUS P3V4X Motherboard, 3 ATA-100 hard drives (all controlled
    >> by an ATA/100 Promise PCI controller,) a CD-RW drive, 3 CD-ROM drives, a
    >> 3COM NIC, a SoundBlaster PCI card, an AGP video card, and a 3 1/2"
    >> floppy drive.
    >> which I bypassed by pressing F1. The problem was easy enough to
    >> diagnose; somehow the power cable for the floppy disk drive had come
    >> loose from its connector/socket. After WinXP Pro finished its startup
    >> process successfully, I exited Windows by selecting Start | Power Off |
    >> Power button. However, nothing happened. I checked to be sure that the
    >> small wire from the Power button was still plugged into the proper
    >> location on the motherboard. It was. Nevertheless, the computer will
    >> not boot up.
    >> wrong.
    >> Dick Smith
  18. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Ah, a case solved!
    Happy New Year!!
    news:e$hU5PF8EHA.1596@tk2msftngp13.phx.gbl...
    > newsgroup that have taken an interest. I wound up removing the power
    > supply to one component at a time, starting with the floppy, and checking
    > to see if the PSU would start the computer after each removal. After
    > everything was removed and still no perceptible juice came forth from the
    > PSU, I removed the motherboard to check its mountings as you had
    > suggested. I then found a screw laying under the mobo in such a way that
    > it had to press against the mobo when it was mounted. Oddly enough, I
    > couldn't visually detect any damage to the mobo. So, I removed the screw,
    > remounted the mobo and hooked everything back up. When I pressed the
    > Power button, the computer started and seems to run ok. So, I guess the
    > Dick Smith
    >>>architecture.
    >>> floppy drive.
    >>> not boot up.
    >>> wrong.
    >>> Dick Smith
Computers Windows XP
