Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA-7n400pro2 onboard sound or soundcard?
Forum Motherboards & Memory : Gigabyte - GA-7n400pro2 onboard sound or soundcard?
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Athlon xp3200
2*512 OCZ eb RAM
40gig IBM (c) pri ma
Pioneer slot DVD rom (d) pri sl
LG DVD writer 8* (e) sec ma
Samsung 160 GB (f) sec sl
I'm long overdue for a reformat of C (isn't XP much more forgiving?) and
have read a few threads here about how a sundcard is preferable as on-board
sound uses system resources whereas a soundcard has it's own. I've use the
onboard sound without issue for 2 yrs now but I want to squeeze every last
bit of performance from this setup before going to a 64bit system.
I have a perfectly good Turtle Beach soundcard in a cupboard, should I
install it and disable on-board sound for better overall performance?
Thanks.
Sponsored Links
On Thu, 24 Mar 2005 12:45:27 GMT, "Joe Soap" <joe@soap.com> wrote:
>Athlon xp3200
>2*512 OCZ eb RAM
>Thanks.
So it uses 'resources'....
What KIND of 'resources' are you concerned about?
I would be VERY surprised if one could even MEASURE any difference in
'performance' ( and performance of what - background/forground CPU
load? Video Perf? HD Perf?) LET ALONE 'feel'/sense any difference.
Personally, unless there is an AUDIBLE differnce in going with a
separate/add-in card that you like, OR there is some functional
difference (HW or SW) that you like/want, etc. I would go with
whatever is most convenient which means I would prob. user the
on-baord sound HW.
Reply to Anonymous
There are 1401 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
