ATI has a problem in the latest Catalyst drivers. Read more
In the weird world of quantum computing, the state of computer systems networked together is so fragile that a read access to a single quantum bit, or qubit, on one machine would require a network-wide reset. Read more
People in southern Florida were hit with a massive power outage after two nuclear reactors spontaneously shut down. The outage centered on the Miami-Dade area, but also extended to some parts of Broward County. Nuclear Regulatory Commission reps say the reactors were probably responding to a weird reading in the power grid and add that everything should be back to normal shortly. Read more
Most booths at the Consumer Electronics Show are pretty bland, but Spectra International's booth stood out with several walls of eye-searing pink Hello Kitty electronics. The cat face with its trademark missing mouth, a symbol of international cuteness, was plastered on everything from phones to USB sticks. There were even Hello Kitty toasters and hair dryers on display. Read more
Does your aging CrossFire-compatible motherboard have enough PCI Express bandwidth to make a second card worthwhile? We compare every Core 2-based platform in order to find out. Read more
Intel's Celeron-based SS4200-E is the company's latest effort to clinch market share in the SOHO storage space. Is it enough to usurp more established incumbents? Read more
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, though, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Usually, green hardware means you're giving up performance in order to cut back on power consumption. But Western Digital's second-generation Green Power drive changes all of that. Read more
| Bottom | |
| Author |
Thread : Weird USB problem...
