Does this system have what it takes to run Mame?
Archived from groups: alt.games.mame (More info?)
I asked this a couple weeks ago here but I'm having some trouble running
some games in my cabinet. I've got an Athlon 500 with 256mb RAM and some
games are REALLY choppy. So far NBA Hangtime and Hangtime Extreme are
completely unplayable. Strangely enough so is P-47 which is odd because its
just a little side-scrolling shooter, nothing fancy about it whatsoever.
Anyways, I'm using Mamewah 161 with command-line Mame .91. I'm hoping it is
a problem with my setup rather than my hardware. Any ideas?
7 answers Last reply
More about does system takes mame
  1. Archived from groups: alt.games.mame (More info?)
    On Thu, 24 Feb 2005 11:39:21 -0600, "MikeC" <someone@hotmail.com>
    The apparent visual complexity of a game is no indication of what CPU
    speed is required to run it adequately. Your hardware is much to
    limited to run the games you mention. As Roman says, go for 3Ghz+ for
    better emulation.
    Cheers,
    Terra Cresta
    PC Arcade
    http://www.pcarcade.tv
  2. Archived from groups: alt.games.mame (More info?)
    Get a CPU somewhere around 3GHz.
  3. Archived from groups: alt.games.mame (More info?)
    Roman Scherzer thought about it a bit, then said...
    My general recommendation is that a 1Ghz system is the "minimum specs" -
    it'll run most of the 80's games at close to 100% speed. Higher
    processor speeds can allow use of 90's games, but after that, however,
    there isn't a processor fast enough.
    Kevin Steele
    RetroBlast! Retrogaming News and Reviews
    www.retroblast.com
  4. Archived from groups: alt.games.mame (More info?)
    On Thu, 24 Feb 2005 18:14:57 GMT, Terra Cresta <t
    >better emulation.
    >Cheers,
    >Terra Cresta
    >PC Arcade
    Even my system with 3.4 GHZ P4-HT and 1 Gig RAM isn´t fast enough to
    play the Games you mentioned smoothly...
    Excample: Gauntlet Legends at 10 FPS...forget it!
  5. Archived from groups: alt.games.mame (More info?)
    Grab a copy of fastmame. ( www.geoshock.com ) Email the author if you
    really need a DOS compile.
    Thnik about it!
    Dead_Dad
  6. Archived from groups: alt.games.mame (More info?)
    Kevin Steele wrote on 24. February 2005:
    Have a 233 Mhz here. Most of the early 80s games run nice.
    By(e) Andreas
    Old school arcade classics at http://www.tombstones.org.uk/~ankman/
    Linux without installation? http://www.knopper.net/knoppix/index-en.html
    OE user? Ease the pain and try the better newsreader http://xnews.newsguy.com/
    Registered as user #289125 with the Linux Counter http://counter.li.org/
  7. Archived from groups: alt.games.mame (More info?)
    Your 'little side-scrolling shooter' has two 68k processors, running at 12
    and 7MHz respectively, and *3* sound chips! It's no wonder your 500MHz
    machine can't handle it!
    Also, hangtime has a 6MHz DSP, whose instruction set is a lot more complex
    and hence more costly to emulate than its 6MHz would imply. There also seems
    to be some pretty serious graphics moving around there so again, don't be
    surprised.
    I've got an 800MHz laptop that I use for playing around on and I don't
    expect to get much more than Frogger, Pacman, Space Invaders etc running on it.
    Regards,
    | Mark McDougall | "Electrical Engineers do it
    | <http://members.iinet.net.au/~msmcdoug> | with less resistance!"
Games Command Line Video Games
