G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hi
I'll get right to it ... I had 1 gig of ram (Kingston 2x512 meg DS
PC-3200) and went out and bought 2 more Kingston 2x512 meg SS PC-3200.
Placed them in order in which the manual told me to dealing with DS and
SS ... Anyways with all 4 Dimm slots filled the computer will boot and
will read 2 gigs yet won't go to the XP start up screen. It just kind
of hangs. If I take out the last one (DIMM 4) It will work fine, no
problems. I tired changing voltage to +1 and +2 and still with all 4 no
go. I have tested all 4 pieces of Ram and they all work perfect alone. I
have both SP 1 and 2 updates. Also have the latest in Bios updates F11.
So Where to now?
Also i installed a new harddrive and now all my usb ports are reading
1.1 when they should all be 2.0. I uninstalled them in hopes on a
reboot it will pick it up but no go. I also Downloaded USB 2 stuff from
the gigibyte web site but no dice. Same error all the time "This USB
device can perform faster if you connect to a USB 2.0 port click here
for the list of open ports" and i go there and well its all my ports
that are open anyways ... BLAH BLAH BLAH.
Anyways if anyone has any advice that would be great!
Thanx
Eyezie
Hi
So Where to now?
Thanx
Eyezie
