Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > USB problem on 8KNXP
Forum Motherboards & Memory : Gigabyte - USB problem on 8KNXP
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I have a trusty USB stick which I have used for the last two years with no
problems.
Today it is suddenly an unrecognized device on each of 4 different USB
sockets connected to my Gigabyte 8KNXP rev 2 motherboard. (Windows XP, SP2)
It works perfectly in my wife's (my old :-) ) Gigabyte 8KNXP rev 1
motherboard on her PC.
I have deleted the 'unrecognized device' in device manager. I have rebooted.
I have tried various different USB sockets. None of these work.
The only recent changes to the machine are a new wireless (Logitech) Laser
MX mouse (which is connected to the mouse port) - replacing a MS optical
mouse connected to the same mouse port; and a new LG DVD RW/RAM burner
replacing an older DVD RW burner.
Any ideas?
Sponsored Links
"Bioboffin" <Reply_to_Group_please@zzz.invalid> wrote in message
news:4sW6e.23432$kr.15341@newsfe1-gui.ntli.net...
>no problems.
> SP2)
> rebooted. I have tried various different USB sockets. None of these
> work.
> Laser MX mouse (which is connected to the mouse port) - replacing a MS
> optical mouse connected to the same mouse port; and a new LG DVD RW/RAM
> burner replacing an older DVD RW burner.
> Any ideas?
Is it visible in disk manager?.
Was any software installed with the DVD-RW?.
It sounds as if the system is no longer automatically mounting the
filesystem. Some CD writing packages can cause changes in this area.
Best Wishes
Reply to Anonymous
>> with no problems.
>> USB sockets connected to my Gigabyte 8KNXP rev 2 motherboard.
>> (Windows XP, SP2)
>> work.
>> MS optical mouse connected to the same mouse port; and a new LG DVD
>> RW/RAM burner replacing an older DVD RW burner.
>> Any ideas?
> Best Wishes
Thanks for the quick response...
It doesn't appear in disk manager.
No software was installed with the DVD-RW. I use Nero and assorted other
packages, e.g. Ulead Movie Factory, which I am reasonably happy with. So I
didn't install any of the packages that came with the DVD. I have updated
the DVD firmware to the latest version.
Reply to Anonymous
I had a similar problem with an old usb cd writer. What I did was uninstall
everything under the USB controllers in the device manager and rebooted.
Windows reinstalled all my devices including my cd writer. I don't know if
it would work for you, but maybe it will.
>problems.
> SP2)
> rebooted. I have tried various different USB sockets. None of these work.
> Any ideas?
Reply to Anonymous
> uninstall everything under the USB controllers in the device manager
> and rebooted. Windows reinstalled all my devices including my cd
> writer. I don't know if it would work for you, but maybe it will.
>> with no problems.
>> (Windows XP, SP2)
Thanks for the help. I tried my usb stick in three other computers today.
All failed to recognise it. I bought a new USB stick and now all is (almost)
well.
The odd thing is, that my old usb stick still works in my wife's pc. So I
have copied off all the files.
And now the front USB socket on my Gigabyte mobo no longer works - for
either old or new; so I'm using the cable from a rear connector (the old
stick doesn't work there either). The new stick is USB 2, so maybe the front
socket only works with USB 1.1. OTOH...
So overall, I think the old USB drive was kaputt. It could have caused
knock-on effects in the mobo circuitry.
John.
Reply to Anonymous
>>> with no problems.
>>> (Windows XP, SP2)
> today. All failed to recognise it. I bought a new USB stick and now
> all is (almost) well.
> So I have copied off all the files.
> old stick doesn't work there either). The new stick is USB 2, so
> maybe the front socket only works with USB 1.1. OTOH...
My wife's PC no longer boots - not even the BIOS. This could be a
coincidence, but I'm wondering if the USB drive has drawn excess current
from the mobo, and led to its demise.
Any comments welcome.
John.
Reply to Anonymous
news:uJe7e.35$DU6.23@newsfe1-gui.ntli.net...
: >> "Bioboffin" <Reply_to_Group_please@zzz.invalid> wrote in message
: >> news:4sW6e.23432$kr.15341@newsfe1-gui.ntli.net...
: >>> I have a trusty USB stick which I have used for the last two years
: >>> with no problems.
: >>> Today it is suddenly an unrecognized device on each of 4 different
: >>> USB sockets connected to my Gigabyte 8KNXP rev 2 motherboard.
: >>> (Windows XP, SP2)
: > Thanks for the help. I tried my usb stick in three other computers
: > today. All failed to recognise it. I bought a new USB stick and now
: > all is (almost) well.
: > The odd thing is, that my old usb stick still works in my wife's pc.
: > So I have copied off all the files.
: > And now the front USB socket on my Gigabyte mobo no longer works - for
: > either old or new; so I'm using the cable from a rear connector (the
: > old stick doesn't work there either). The new stick is USB 2, so
: > maybe the front socket only works with USB 1.1. OTOH...
: > So overall, I think the old USB drive was kaputt. It could have caused
: > knock-on effects in the mobo circuitry.
: My wife's PC no longer boots - not even the BIOS. This could be a
: coincidence, but I'm wondering if the USB drive has drawn excess current
: from the mobo, and led to its demise.
: Any comments welcome.
: John.
Hi John
When I was checking out the GA-8ik1100, which is your boards little sister,
I came across a 'recognised' problem with usb and the Intel ICH5R chipset.
I'm afraid I didn't bookmark the page, but with a bit of googling you should
find it. I'm not suggesting that's what your problem is, but IIRC it was
similar.
PL
Reply to Anonymous
>>>>> with no problems.
>>>>> (Windows XP, SP2)
>>> for either old or new; so I'm using the cable from a rear connector
>>> (the old stick doesn't work there either). The new stick is USB 2,
>>> so maybe the front socket only works with USB 1.1. OTOH...
>>> caused knock-on effects in the mobo circuitry.
>> current from the mobo, and led to its demise.
>> John.
> Hi John
> sister, I came across a 'recognised' problem with usb and the Intel
> ICH5R chipset. I'm afraid I didn't bookmark the page, but with a bit
> of googling you should find it. I'm not suggesting that's what your
> problem is, but IIRC it was similar.
Thanks - I'll check it out.
John
> PL
Reply to Anonymous
>>>>>> years with no problems.
>>>>>> different USB sockets connected to my Gigabyte 8KNXP rev 2
>>>> pc. So I have copied off all the files.
>>> John.
>> Hi John
I'm afraid I was unable to come up with anything relevant. However, thanks
for the suggestion.
I'm buying a new mobo for my wife's pc and I have already bought a new usb
stick. Philosophically (!) I guess the cash always solves the problem!!!
John.
Reply to Anonymous
There are 973 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
