Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > problem on USB external hard drive
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
My sonic external hard drive(usb 2.0,160G) suddenly stoped
working,the little light also stop blinking.
Is it broken?Any idea?
Thanks
Sponsored Links
Check if the device is working when connected to another PC.
If its still not working, it might be broken.
To prevent such failures, do this before you plug out USB devices from ur PC.
1. On the taskbar, right-click on the Safely Remove Hardware Icon (the one
wit the green arrow)
2. Select Safely Remove Hardware and select the device which u want to remove.
3. Click stop. You will receive a msg that the device can be removed safely.
> Thanks
Reply to Anonymous
No light equals no power. Does your external drive have a powerpac that
plugs into the wall - as mine does? Check your connections. Do you have a
cat? They love to chew wires. I lost 2 that way over the years. (-:
Regards,
Richard Urban
aka Crusty (-: Old B@stard :-)
If you knew as much as you thought you know,
You would realize that you don't know what you thought you knew!
"insistcool" <insistcool@hotmail.com> wrote in message
news:107701c4f21c$2820c9a0$a301280a@phx.gbl...
> Thanks
Reply to Anonymous
Cats or wires?
"Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message
news:O6eDFxm8EHA.3840@tk2msftngp13.phx.gbl...
> Regards,
> Richard Urban
> > Thanks
Reply to Anonymous
Actually meant to put Cats frying are OK but hate to lose those wires.
"LVTravel" <none@nothere.com> wrote in message
news:10tloq59bonc1e3@corp.supernews.com...
> Cats or wires?
a
> > Regards,
> > Richard Urban
> > > Thanks
Reply to Anonymous
There are 532 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
