Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I HAVE A LAPTOP ZEPTO ZNOTE 4200. I RECENTLY CONNECTED IT TO MY PC VIA USB
CABLE. WHEN REMOVING THE CABLE I SAFELY REMOVED IT FROM MY PC FIRST AND THEN
UNPLUGGED IT. AND THEN I GOT A WHITE SCREEN ON THE LAPTOP THAT WUDNT GO. I
HAD TO COLD REBOOT. AFTER REBOOTING WHENEVER I CONNECT ANY USB DEVICE TO MY
LAPTOP IT SAYS BANDWIDTH EXCEEDED PRESS RESET TO RESET THE USB PORT OR PRESS
CLOSE TO CLOSE THIS WINDOW.......IF YOU PRESS CLOSE YOU WILL NOT BE ABLE TO
USE THE USB PORT. EVEN AFTER RESETTING I GOT THIS ERROR WHENEVER I CONNECTED
AND USB DEVICE. SO IN THE END I TRIED PRESSING CLOSE. AND SINCE THEN I HAVNT
BEEN ABLE TO USE ANY OF MY 3 USB PORTS. NOW IT DOESNT EVEN DETECT WHEN I PLUG
IN A DEVICE. I ALREDY WENT INTO THE DEVICE MANAGER AND CHECKED THE PORTS AND
THE HUB .........IT SAYS THEY ARE WORKING FINE. I EVEN TRIED REINSTALLING THE
DRIVERS BUT TO NO AVAIL. PLS HELP!!--
GAURAV
GAURAV
