Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA-K8NS Ultra-939 and Smart Fan Control Problem
Forum Motherboards & Memory : Gigabyte - GA-K8NS Ultra-939 and Smart Fan Control Problem
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I just bought the GA-K8NS Ultra-939 along with an Athalon 64 3200+ in a
retail box (standard AMD fan). When I hooked everything up, the CPU fan
stopped running while I was setting up the inital bios settings. The
CPU fan fail alarm immediately went off. I then turned the smart fan
control off to avoid frying my CPU and everything appears to work. My
question is according to the manual (yes I did read it) the fan speed
is reduced if the temperature is lower then 40 c. I assume reduce means
it is still running not stopped. Is this normal? Needless to say, I
didn't wait for the cpu to haet up to see if it start running again.
Other than that, the board seems fine. I would still like to use this
feature if it actually works.
Sponsored Links
Normal
<phughes200@hotmail.com> wrote in message
news:1114206280.922578.174680@z14g2000cwz.googlegroups.com...
Reply to Anonymous
There are 1169 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
