G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I have the following hardware (purchased in February)::
1 Cooler Master Centurion 5, ATX Mid Tower Case, 350W PSU, Silver
1 Gigabyte GA-8I915P Duo Pro motherboard, Socket 775, Intel 915P
Chipset, 800MHz FSB, 1xPCIe-16, 2xPC
1 Gigabyte GeForce 6600 video card, 128MB DDR, PCIe-16, GeForce 6600,
TV Out, DVI
1 Intel Pentium 4 550, 3.4 GHz CPU, 800MHz FSB, Prescott Socket 775,
Retail pack with fan
1 Kingston Dual Channel Memory Kit, 2x512MB, DDR-SDRAM, DIMM, DDR400
1 Logitech Cordless Desktop LX500, Keyboard & Optical Mouse, PS/2 & USB
1 Microsoft Windows XP Professional
1 Pioneer DVR-109, Dual Layer DVD Writer, DVD 16R/16W/8RW, CD
40R/40W/24RW, Internal, IDE, OEM, Black
2 Seagate Barracuda 7200.7 ST3160827AS, 160 GB, 7,200rpm, 8192K cache,
SATA-150, Fluid Bearing, NCQ
1 Seagate Barracuda 7200.7 ST380011A, 80 GB, 7,200rpm, 2048K cache,
ATA-100, Fluid Bearing Hard Disk
1 Sony MPF920S, 1.44MB, Internal, Floppy Disk Drive
When I first put it all together it used to randomly reboot all the time.
e.g. during the windows install.
I did lots of fresh windows installs to try and see if it would go away.
Eventually I had the motherboard replaced.
After installing the new motherboard I did a fresh windows install without
any reboot.
Currently the PC will still reboot at random but normally when I am not
using it.
For example. I can capture 1 hour of video without reboot. Write 4 gig to a
DVD disk without reboot.
It tends to reboot more often when I'm not actually running any program. e.e
if I leave the PC over night (even with standby tuened off)
It will also reboot if I try and put it in standby mode.
Testing I have done.
Tested the memory using memtest-86, both as 1 Gig and with only on DIMM in -
not error, reboot problem doesn't go away with either 512 meg DIM in.
Tested disk drives using seagate tools.
I took the video card back to supplier and they say it tested ok.
Used SpeedFan to check CPU temp
I have installed all the latest drivers.
From Gigabytes EasyTune 5 I have the following:
CPU FSB 200 Voltage 1.38
Memory Freq 400 Voltage 2.6
VCoreA 1.32
+3.3v 3.180
+21v 11.410
Cpu Temperature 32 deg C
I'm about to send the Video card back for replace as I have run out of
ideas.
Can anyone suggest what the problem might be.
TV Out, DVI
any reboot.
using it.
VCoreA 1.32
+3.3v 3.180
+21v 11.410
ideas.
