Archived from groups: microsoft.public.windows.networking.wireless (More info?)
HELP
I HAVE A TWO PCS BOTH WITH WIFI CARDS IN BOTH SEEM TO WORK, THEY PICK UP TWO
CONNECTIONS ABC123 AND LINKSYS.
THESE MUST BE NAYBOURS OR SOMETHING
I'VE CALLED MY TWO - UP AND DOWN, WHEN SERCHING FOR AVALABLE CONNECTIONS I
CANT FIND EITHER.
I'VE DONE THE WIRELESS NETWORK WIZZARD AND THE HOME NETWORK WIZZARD; I'M
RUNNING XP HOME ON ONE PC AND XP PRO ON THE OTHER.
I ALSO HAVE A WIRELESS IPAQ THAT ONLY FINDS ABC123 AND LINKSYS.
HELP
A very confusing post I must say. Are you not seeing your network? Is that
the problem?
You have 2 PCs with wireless cards. What Models? Also are you using a
router?(What Model) or trying to setup an AD-HOC network?
Robert...
"c_bcan" <ellisa2079@yahoo.com> wrote in message
news:69CYd.1480$Bo5.1338@newsfe4-gui.ntli.net...
> HELP
> TWO CONNECTIONS ABC123 AND LINKSYS.
> CANT FIND EITHER.
> HELP
thanks for your help i've got a realtek rtl8180 and a tl-wn250, i'm not
using a router, i want to share files and an internet conection.
"DLink Guru" <rjacobs0spamfree@pacbell.net> wrote in message
news
rE5PNyJFHA.484@TK2MSFTNGP15.phx.gbl...
>the problem?
> Robert...
>> HELP
>> I CANT FIND EITHER.
>> HELP
What Operating Systems and service packs are you using?
The tl-wn250 is a 802.11b PCI card for a desktop. The rtl8180 just tells me
what chipset you are using. Is this a wireless adapter or a Ethernet NIC?
Also is this in a laptop or another desktop?
If you are not going to use a router you must setup your wireless adapters
for a AD-HOC network, not an infrastructer network. Are you using the client
software or windows to configure your network adapters? Each adapter must be
set for AD-HOC, using the same SSID, same authentication and same security
settings before it can work. You can also tell them to ignore Infrastructure
networks so those others will not showup on your available networks list.
Robert...
news:w8HYd.2393$Bo5.929@newsfe4-gui.ntli.net...
> news
>>the problem?
>> Robert...
>>> HELP
>>> I CANT FIND EITHER.
>>> HELP
thanks
right both set to ad hock ssid set to pc, network address set to 10.170.20.1
on one pc and 10.170.20.2 on the other
both desktops, both using xp home one with all updates one with none (need
to get this internet connection)
the tl-wn250+ is a wireless lan pci adapter
trying to use windows to config not there software
news:%23JfuOmzJFHA.3084@TK2MSFTNGP10.phx.gbl...
> me what chipset you are using. Is this a wireless adapter or a Ethernet
> NIC? Also is this in a laptop or another desktop?
> client software or windows to configure your network adapters? Each
> adapter must be set for AD-HOC, using the same SSID, same authentication
> and same security settings before it can work. You can also tell them to
> ignore Infrastructure networks so those others will not showup on your
> Robert...
>> news
>>>that the problem?
>>> Robert...
>>>> HELP
>>>> UP TWO CONNECTIONS ABC123 AND LINKSYS.
>>>> CONNECTIONS I CANT FIND EITHER.
>>>> I'M RUNNING XP HOME ON ONE PC AND XP PRO ON THE OTHER.
>>>> HELP
ok, so what does the wireless conection say in the system tray on both
computers? Does it show you are connected?
Robert...
news
8SYd.21$5M4.19@newsfe3-gui.ntli.net...
> thanks
> 10.170.20.1 on one pc and 10.170.20.2 on the other
>> adapters for a AD-HOC network, not an infrastructer network. Are you
>> using the client software or windows to configure your network adapters?
>> Each adapter must be set for AD-HOC, using the same SSID, same
>> authentication and same security settings before it can work. You can
>> also tell them to ignore Infrastructure networks so those others will not
>> Robert...
>>> news
>>>>that the problem?
>>>> Robert...
>>>>> HELP
>>>>> HELP
no not unless I try and connect to abc123 or linksys, they will allow me to
connect but will not send any data, obviously encrypted
news:epLfkD6JFHA.2136@TK2MSFTNGP14.phx.gbl...
> Robert...
> news
>> thanks
>> (need to get this internet connection)
>>> Robert...
>>>> news
>>>>>that the problem?
>>>>> Robert...
>>>>>> HELP
>>>>>> HELP
What about the Subnet, what is it set for? Set it to something like
255.255.255.0 on both machines. What about firewalls? Disable any that are
running.
news:aqSYd.26$5M4.11@newsfe3-gui.ntli.net...
> to connect but will not send any data, obviously encrypted
>> Robert...
>> news
>>> thanks
>>>> tells me what chipset you are using. Is this a wireless adapter or a
>>>> Ethernet NIC? Also is this in a laptop or another desktop?
>>>> adapters? Each adapter must be set for AD-HOC, using the same SSID,
>>>> same authentication and same security settings before it can work. You
>>>> can also tell them to ignore Infrastructure networks so those others
>>>> Robert...
>>>>> not using a router, i want to share files and an internet conection.
>>>>> news
>>>>>>that the problem?
>>>>>> Robert...
>>>>>>> HELP
>>>>>>> PICK UP TWO CONNECTIONS ABC123 AND LINKSYS.
>>>>>>> HELP
yes it is set to that and fire walls are off
news:%23Hv08X6JFHA.4064@tk2msftngp13.phx.gbl...
> running.
>>> Robert...
>>> news
>>>> thanks
>>>>> Robert...
>>>>>> news
>>>>>>>that the problem?
>>>>>>> a router?(What Model) or trying to setup an AD-HOC network?
>>>>>>> Robert...
>>>>>>>> HELP
>>>>>>>> WIZZARD; I'M RUNNING XP HOME ON ONE PC AND XP PRO ON THE OTHER.
>>>>>>>> HELP
I seem to have them both connected to my network now called "bob" but they
will only see themselves not each other both are transmitting but not
receiving.
news:__SYd.38$5M4.23@newsfe3-gui.ntli.net...
>> are running.
>>>> Robert...
>>>> news
>>>>> thanks
>>>>>> You can also tell them to ignore Infrastructure networks so those
>>>>>> Robert...
>>>>>>> news
>>>>>>>>Is that the problem?
>>>>>>>> Robert...
>>>>>>>>> HELP
>>>>>>>>> HELP
ok I now have them sharing, I'm transferring a file that's 1.6 gig and its
taking 100 mins is that normal? also I now need to set up the internet
sharing.
news:bzTYd.44$5M4.14@newsfe3-gui.ntli.net...
>receiving.
>>> are running.
>>>> me to connect but will not send any data, obviously encrypted
>>>>> Robert...
>>>>> news
>>>>>> thanks
>>>>>>> Robert...
>>>>>>>> conection.
>>>>>>>> news
>>>>>>>>> using a router?(What Model) or trying to setup an AD-HOC network?
>>>>>>>>> Robert...
>>>>>>>>>> HELP
>>>>>>>>>> HELP
That seems a bit slow, about 250KBs, There could be interferance and
distance between computers will also be a factor, and antivirus programs
will slow it down also.
Now for internet sharing, run the wireless network wizard on the computers
and set the computer connected to the internet to share its connection and
set the other to connect through another computer.
Robert...
news:5NTYd.45$5M4.27@newsfe3-gui.ntli.net...
> sharing.
>>receiving.
>>>> are running.
>>>>>> both computers? Does it show you are connected?
>>>>>> Robert...
>>>>>> news
>>>>>>> thanks
>>>>>>>> a Ethernet NIC? Also is this in a laptop or another desktop?
>>>>>>>> you using the client software or windows to configure your network
>>>>>>>> Robert...
>>>>>>>>> i'm not using a router, i want to share files and an internet
>>>>>>>>> conection.
>>>>>>>>> news
>>>>>>>>>> Robert...
>>>>>>>>>>> HELP
>>>>>>>>>>> HELP
The two pcs are in the same small room so distance isn't a factor, I notice
its taking almost all of my system recourses to send this file cpu`s at 98%,
I'll try the internet sharing wizard.
Thanks
news:ucilba7JFHA.2212@TK2MSFTNGP12.phx.gbl...
> Robert...
>> its taking 100 mins is that normal? also I now need to set up the
>> internet sharing.
>>>they will only see themselves not each other both are transmitting but
>>>not receiving.
>>>>> are running.
>>>>>>> Robert...
>>>>>>> news
>>>>>>>> thanks
>>>>>>>> none (need to get this internet connection)
>>>>>>>>> SSID, same authentication and same security settings before it can
>>>>>>>>> work. You can also tell them to ignore Infrastructure networks so
>>>>>>>>> Robert...
>>>>>>>>>> conection.
>>>>>>>>>> news
>>>>>>>>>>>network? Is that the problem?
>>>>>>>>>>> network?
>>>>>>>>>>> Robert...
>>>>>>>>>>>> HELP
>>>>>>>>>>>> THEY PICK UP TWO CONNECTIONS ABC123 AND LINKSYS.
>>>>>>>>>>>> HELP
Right I now have internet as well thanks for all your help
news:bDUYd.68$5M4.49@newsfe3-gui.ntli.net...
> notice its taking almost all of my system recourses to send this file
> cpu`s at 98%, I'll try the internet sharing wizard.
> Thanks
>> computers and set the computer connected to the internet to share its
>> connection and set the other to connect through another computer.
>> Robert...
>>> internet sharing.
>>>>not receiving.
>>>>>> that are running.
>>>>>>> allow me to connect but will not send any data, obviously encrypted
>>>>>>>> Robert...
>>>>>>>> news
>>>>>>>>> thanks
>>>>>>>>>> just tells me what chipset you are using. Is this a wireless
>>>>>>>>>> adapter or a Ethernet NIC? Also is this in a laptop or another
>>>>>>>>>> desktop?
>>>>>>>>>> network adapters? Each adapter must be set for AD-HOC, using the
>>>>>>>>>> same SSID, same authentication and same security settings before
>>>>>>>>>> networks list.
>>>>>>>>>> Robert...
>>>>>>>>>>> conection.
>>>>>>>>>>> news
>>>>>>>>>>>> network?
>>>>>>>>>>>> Robert...
>>>>>>>>>>>>> HELP
>>>>>>>>>>>>> OTHER.
>>>>>>>>>>>>> LINKSYS.
>>>>>>>>>>>>> HELP
Glad to be of assistance.......
news:MpVYd.18604$3A6.7014@newsfe1-gui.ntli.net...
>> Thanks
>>> Robert...
>>>> internet sharing.
>>>>>not receiving.
>>>>>>> that are running.
>>>>>>>>> Robert...
>>>>>>>>> news
>>>>>>>>>> thanks
>>>>>>>>>>> desktop?
>>>>>>>>>>> wireless adapters for a AD-HOC network, not an infrastructer
>>>>>>>>>>> network. Are you using the client software or windows to
>>>>>>>>>>> configure your network adapters? Each adapter must be set for
>>>>>>>>>>> Robert...
>>>>>>>>>>>> conection.
>>>>>>>>>>>> news
>>>>>>>>>>>>> network?
>>>>>>>>>>>>> Robert...
>>>>>>>>>>>>>> HELP
>>>>>>>>>>>>>> OTHER.
>>>>>>>>>>>>>> LINKSYS.
>>>>>>>>>>>>>> HELP
There are 711 identified and unidentified users. To see the list of identified users, Click here.
