Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > Dead 8KNXP - due to the front panel USB static problem
Forum Motherboards & Memory : Gigabyte - Dead 8KNXP - due to the front panel USB static problem
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Well, my 8 month-old 8KNXP finally succumbed to the front panel USB static
problem (i875P chipset) and won't POST. A couple of months ago, it started
having problems recognizing USB devices from front panel. I finally plugged
in one USB device too many and the (literal) shock killed it.
I have an RMA number and it's going back this week.
I had setup RAID-0 arrays on both the Intel and Si3112 controllers, and was
nervous about being able to recover them.
So, I bought an ABIT IC7-G this weekend, swapped MOBOs and happily read the
existing RAID-0 sets!
Sponsored Links
> static problem (i875P chipset) and won't POST. A couple of months
> ago, it started having problems recognizing USB devices from front
> panel. I finally plugged in one USB device too many and the
> and was nervous about being able to recover them.
> read the existing RAID-0 sets!
Is there a "ground" pin somewhere on these boards?
Reply to Ian
There are 1120 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
