Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA 7N400 Pro2 - Memory Problem
Forum Motherboards & Memory : Gigabyte - GA 7N400 Pro2 - Memory Problem
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hi there,
I've been using my current setup for the past months and decided to
try out a memory boost. I've been running an AMD 3000+ (32bit) on my
board, with 1gig of ram (OCZ PC3500 Dual Kit, 2x512MB (I realise the
motherboard only supports PC3200 so it's running as such) and
everything's been swimmingly.
Keeping with the setup, I bought another dual kit of OCZ PC3200 this
time, 2x512MB.
However, when I go to install them, both the BIOS, System Info in
Windows, and the boot screen shows that I only have the 1gig
operating. I tried swapping in a friend's 4 512 pieces of 3200 which
work on his computer (different board), with no luck. I also made
sure these two new chips worked by having only them in and they work
fine.
Am I missing a setting in my BIOS, or a jumper somewhere? Any help or
guidance would be appreciated... I'm baffled as to why its not
working.
Thanks for the help.
Sponsored Links
>time, 2x512MB.
>operating.
>working.
You are trying to use 4 doublesided Modules and this will not work
according to the manual.
You can only use 2 doublesided and 2 singlesided Modules together when
using all 4 memoryslots.
bye
Heiko
Reply to Anonymous
Correct.
"edge" <gtp.edge@shaw-dot-ca.no-spam.invalid> wrote in message
news:2acd0$4275d76e$455da0d2$25542@allthenewsgroups.com...
> Hi there,
> time, 2x512MB.
> fine.
> working.
Reply to Anonymous
Rudy Kazuti wrote:
>Correct.
bye
Heiko
Reply to Anonymous
I am assuming that both sets of RAM are Dual SIded (meaning they have
chips on both sides), If this is the case, they WILL NOT WORK. You
can use 2 DS RAM, and 2 SS (Single Sided) RAM
On Wed, 4 May 2005 20:42:11 -0400, "Rudy Kazuti"
<rudykube@comcast.net> wrote:
>Correct.
>> Hi there,
>> time, 2x512MB.
>> fine.
>> working.
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! >100,000 Newsgroups
---= East/West-Coast Server Farms - Total Privacy via Encryption =---
Reply to Anonymous
There are 1092 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
