Problem with a GeForce 4 mx 440
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Recently buy a card of video GeForce4 mx 440, I could finally install it
without problems, but now when I try to use some game, the screen becomes
black and my computer is restarted.
Can somebody help me?
G
Guest
Guest
Don't use THAT game.
If you gave some DETAILS, you would get a better answer.
"Flaco" <Flaco@discussions.microsoft.com> wrote in message
news:2E614E69-1CA7-4C0B-BC92-7DDC2310E826@microsoft.com...
finally install it
screen becomes
G
Guest
Guest
That card only claims support for DirectX up to 8.1. Are you if you are
installed DirectX 9 and the "game" invokes a feature the card does not
support, the black screen would be expected result. Please verify game
requirements and installation.
G
Guest
Guest
Check with the game's publisher. Serveral games (like Prince of Persha) do
not support any MX video cards.
kyle
145
i installed the similar video card.. was a GeForce 5200 and the screen goes
black but the speakers still give off the games sound.. have you solved your
problem?
G
Guest
Guest
Hey
the going black and restarting of the pc while playing games is a typical
failure of a power supply that doesn't meet your gfx cards requirements.
Check your powersuply and the output on the +5V and +12 V lines, and if
inadequate get yourself a cheap 400 Watt PSU which should solve the problem.
