Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hello All
I have just built a new PC based on the GA-K8NXP-9 motherboard - everything
was working a treat.
All of a sudden the sound does not appear to work at all. When I try to use
the volume control on WinXP it says:-
There are no active mixer devices available. To install mixer devices, go to
Control Panel, click Printers and Other Hardware, and then click Add
Hardware.
Hello All
I have cracked this one myself!
I installed the latest F5 BIOS and it reset the AC97 AUDIO to DISABLED.
Sorry for being so slow but this may affect other users.
I would also like to mention that Nvidia's iTune software now works.
AlsoGigabyte's EasyTune now has the Smart Fan button highlighted.
Hope this info helps.
Mike Clements
"MikeC" <anon> wrote in message
news:428bcd7a$0$325$cc9e4d1f@news.dial.pipex.com...
> Hello All
> everything was working a treat.
> use the volume control on WinXP it says:-
> to Control Panel, click Printers and Other Hardware, and then click Add
> Hardware.
> Any ideas what I should be looking for?
> Any advice much appreciated.
> Thanks
> Mike Clements
> Any ideas how I should proceed?
"MikeC" wrote:
> Hello All
> DISABLED.
> works.
> highlighted.
> Mike Clements
> > Hello All
> motherboard -
> When I try to
> mixer devices, go
> then click Add
> > Hardware.
> > Thanks
> > Mike Clements
Hi Mike,
Can you tell me how you re-enabled the AC97 sound mate - having the
same problem!! Hoping you can help. Thanks pal.
Sheefa
