G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hello,
I hope someone is able to help me! I have the above mentioned components,
and cannot get the XP-M 2600+ to be recognised as such in this board. It
gets recognised as an Athlon XP 600MHz... I have tried changing the FSB
settings, but I cannot set the FSB above 132MHz anyway, despite having set
the jumper on the SW1 switch to Auto. Running EasyTune 5 does not solve
anything (although it does recognise that the CPU's highest running
potential is 2800MHz - don't intend to overclock that far, though!), and I
get freezes at (usually) anything over an FSB of 122MHz. The BIOS is up to
date (F5) and I have tried resetting it a few times now under different
configurations.
Does the 7VT600P-RZ have a problem with recognising the Mobile CPUs? I had
heard this may be the case, and particularly with the 2600+ - I am hoping
someone can confirm or deny, or (better yet) be able to help me cure the
problem? If not, I guess I will have to try a fully-fledged XP CPU (don't
particularly want to go for a Sempron), so the names of any recommended
retailers (who are in/will send to the UK) would be appreciated.
Thank you in advance, and thanks for reading.
Hello,
configurations.
