Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
The manual for this board documents a setting in
BIOS where I can set the memory speed multiplier as
follows:
main menu>frequency/voltage control>"memory Frequency for"
manual shows 4 settings for FSB = 800 Mhz: 2.0, 1.6, 1.33, auto
But the BIOS shows only 2.0 and 1.6. I must run my memory at
1.6 or 1.33. How can I see the choices the manual shows?
How can I force the mobo to run at 4:5 memory to FSB
ratio?
Second problem: My BIOS is "F4", date of Feb. 2005.
The gigabyte site shows the latest as "F3" with a
Sep. 2004 date. I D/L F3, but it won't load, I get
an error message and the update stops. How do I
flash the BIOS (I mean besides the normal way which doesn't work)
Anyone else successful at doing this?
Why? You have installed the latest and normally best BIOS by default
and you try to install an older version.
> Udo
Two reasons:
The board has a defect which appears
to be the fault of the BIOS, so changing it is the only
option I have to try to fix this defect.
Also, changing the BIOS serves as a test to determine if
the changing the BIOS is even possible on this board.
