Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
The manual for this board documents a setting in
BIOS where I can set the memory speed multiplier as
follows:
main menu>frequency/voltage control>"memory Frequency for"
manual shows 4 settings for FSB = 800 Mhz: 2.0, 1.6, 1.33, auto
But when I go into BIOS it shows only 2.0 and auto. I must run my memory at
1.6 or 1.33. How can I see the choices the manual shows?
How can I force the mobo to run at 4:5 memory to FSB
ratio?
Second problem: My BIOS is "F4", date of Feb. 2005.
The gigabyte site shows the latest as "F3" with a
Sep. 2004 date. I D/L F3, but it won't load, I get
an error message and the update stops. How do I
flash the BIOS (I mean besides the normal way which doesn't work)
Anyone else successful at doing this?
