Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > overclocking help?
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I have a gigabyte GA-7N400 pro2 nforce with a athlon xp2500+ barton
processor. I would like to overclock it but I don't know how, do any of
you guys know of a web site that can help?
cheers
brian
Sponsored Links
"Brian" <bri_competitions_NO_SPAM@yahoo.co.uk> wrote in message
news:C5WdnTp-HYStSoDeRVnygA@pipex.net...
> cheers
> brian
If all is going well your multiplier must be at 11X.
To start I'd set the switches to 11.5X. That should get you to
11.5X166=1909.
If it fails to boot ( or goes unstable )you have to remove the AC power from
the PowerSupply and reset the BIOS. Use a Jumper if you a Rev 2 Board.
If all goes well try 12X etc.
After that you can go onto Advanced Chipset Features. Here, set System
Performance to Manual and move the FSB up to 167 ( or what ever) and try
it.
If your almost where you want to be but still getting errors you can try
raising the memory and/or the CPU voltage.
I use EasyTune4 to monitor the progress.
Some CPU/memories over clock well and some do the specification and that's
it.
Jim
Reply to Anonymous
There are 1264 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
