Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I recently upgraded my home systems from NT4 SP6a to XP Pro SP2 - so I'm
new here
My NT system had two SCSI disks - drives C: (NT) and D: (software) on
ID0 and drive E: (data) on ID1. To install XP, I added a disk at ID2,
set the host adapter to boot from ID2, and booted from the XP CD.
I now have XP set up the way I like and don't need to retain the ability
to boot NT, so I backed up ID0 to DVD using Drive Image 7.0 and deleted
the disk partitions, leaving me with:
ID0: Unallocated
ID1: drive E:
ID2: drive C: (XP) and D: (software)
Now I'd like to move C: and D: to ID0, so I used Drive Image 7.0 to copy
the partitions and set the host adapter to boot from ID0.
XP boots normally from ID0, I log in, everything looks fine - but after
a minute or so a dialog pops up telling me svchost.exe has encountered a
problem and needs to close. After that the system is unresponsive -
mouse cursor still moves but there's no visible response to clicks or
keyboard input - not even CTRL ALT DEL. If I hit the reset button, XP
boots again but I can't log in - the login dialog re-appears about a
minute later each time I enter my credentials.
I've used Drive Image many times in the past to relocate my NT partition
without problems, and also successfully tested restoring my XP partition
from an image file, so I'm not sure why moving XP causes svchost.exe to
crash.
Any suggestions?
TIA
Sunny
new here
ID0: Unallocated
ID1: drive E:
crash.
Any suggestions?
TIA
Sunny
