Archived from groups: alt.comp.periphs.gigabyte (More info?)
"Terry" <redone22214@excite.com> wrote in message
news:Iu%Ac.5381$3b5.4120@newssvr27.news.prodigy.com...
> I have a Giga-byte GA-7VT600 1394 AMD Motherboard with dual bios and a
> Seagate Hard drive .
> The hard drive has a 160GB capacity,but when I install it with this
> hardware and WindowsXP OEM SP1 software it only comes up as a 150GB
> hard drive.
> Do I need to flash something or change a setting so it see's it as a
> 160GB hard drive.
> Thanks:Terry
IF thats the size you get after formatting, its about right, I should think.
My 36Gb comes out as 34.25, my 60Gb goes down to 55.89 and my 80Gb goes to
74.52
> hard drive.
> 160GB hard drive.
The 160GB is a decimal figure, 149GB is the binary equivalent. If you right
click the drive in Explorer and click Properties you should see both values.
The reason goes back a long way when someone decided to call the value
2^10=1024 a kilobyte because it was so close to a kilo or 1000. Then
2^20=1048576 became Megabyte and 2^30=1073741824 became Gigabyte. There are
moves to change the terminology of binary values but without success so far.
