SSD - The Performance Upgrade of the Future
Archived from groups: alt.comp.periphs.gigabyte (More info?)
Would lke to be able to have speakers plugged into rear audio jack and be able to use headphones in audio jack on front of case. >From MB User manual 1 o o 2 Remove 5-6, 9-10 jumper to utilize the 3 o o front audio header 5 o----o 7 o 9 o----o 10 Pin 1 Mic 2 Gnd 3 Ref 4 Power 5 Front Audio(R) 6 Rear Audio (R) 7 Reserved 8 No Pin 9 Front Audio(L) 10 Rear Audio (L) I have 7 wires coming from mic and speaker jacks on front of case (a 4w and a 3wire labelled as below)) Mic-in (1) Mic-Pwr (4) Ret-R ???? Ground (2) R-Out (5) L-Out (9) Ret-L ?????? Have connect wires to pin number in brackets. What pins should I connect Ret-R and Ret-L to ?????? I have removed 5-6 and 9-10 jumpers Any help much appreciated Merv
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
